Blockshaker101 Posted August 22, 2012 Report Posted August 22, 2012 im working on a 2012 Camaro and im leaving the stock deck in it, i am running a pac-soem for the line converter, a new Lanzar 1200, probabbly putting out 700rms (maybe), and that is pushing a Fusion Johum Lumas 15" with the max at 1600 watts. problem is there is no bass. i have some ideas but i need help to figure it out. I have never used a line out converter and i think im getting to much vocals from the rear speaker and not enough low end or maybe im i not pushing it hard enough. please let me know what you think....thanks guys
Slobalt7 Posted August 22, 2012 Report Posted August 22, 2012 Need more info, like is the amp getting power, is it getting signal, is the sub getting signal, where are your gains at, do you have a low pass switch, where is your fq cutoff, ect. Yeah, it's slower than your bowel movements.
Blockshaker101 Posted August 22, 2012 Author Report Posted August 22, 2012 yeh everything works im sorry i should have proof read i have bass but its weak ive heard better fron a cheap 500 watt amp. no low end at all even with the gain up its not much, with the low fq any where it sucks sounds like a 8 botttoming out
Slobalt7 Posted August 22, 2012 Report Posted August 22, 2012 Well if it clips like an 8 bottoming out it sounds like faulty equipment, I am not really familiar with the equipment you are using but if the sub is dvc you may just have a wiring issue or even a vc burned out. Yeah, it's slower than your bowel movements.
Shankkilla420 Posted August 22, 2012 Report Posted August 22, 2012 Yup.. check your wiring, I did that to a home system a couple days ago. Turned out I was crossed on a wrong coil LOL
ZachG Posted August 22, 2012 Report Posted August 22, 2012 Why put such crappy equipment in a nice new car? 1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
