XS Power
Questions about another battery
Hey guys i have a question. So I have a XS D3400 under the hood and in the mail i have a Mechman 270 amp alt. I will have a run of zero to that with a 250 amp fuse inline. and i will have two grounds off the negative. I am wondering if i get another battery does it have to be the same size battery or can it be a smaller one if i even need one. I am going to power a 3.5k and two level 4 10s for now.
also i am confused on how to run the wire to two batteries can someone clear that up for me please. i feel like a noob but i never have though about running more than one. eventually i will need to know how to with more builds. anyways if someone could help me with the underlined parts it would be great thank you!
2001 GMC Sierra DC Audio Build =http://www.stevemead...o-level-4-build
2001 GMC Sierra
XSPower D3400
Pioneer AVHD 1400
​MB Quart Component Sets
Pioneer 5x4s
Audiotechnix Power Wire, Speaker Wire, Sound Deadener
DC Audio Level 4 10s
DC Audio 3.5k
Rocford Fosgate R400-4
HID 6k
Slammed Truck on 20s
Candy Blue.
no you don't have the same size battery's but i would still get a xs battery as a secondary since you have a d3400
people who have bought from me Team Bassick (ALPINE) Purplehaze nidus
head unit sony dsx-s310btx
subs 2 12 incriminator audio king of bass
subs amp incriminator audio 20.1
mids/highs
mids/highs amp incriminator audio 6.4
equalizer clarion
crossover interfire
alternator 1 mechman 240amp
battery's xs power 1 d2100 2 d3100
sky high car audio 1/0 awg ofc wires
memphis car audio 1/0 ofc
xs power xs flex 4 awg
sky high car audio 8 gauge ofc
sky high car audio 12 gauge ofc
t spec rca
check out my building log http://www.stevemead...frey-build-log/
http://www.stevemead...d-other-things/
check out audio gear i have for sale
http://www.stevemead...51#entry1595151
Battery can be a smaller one if you want. I would get a xp3000 for the back and be done with it. As to hooking them up, It's as easy as connecting the positive to positive and negative to negative ( or a nice chassis ground in the back). Just make sure you fuse within 18" of front batt and 18" before the rear battery and you're good to go.
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
3 cube box 2 6" aeros
XS Power D2400 & Xp950
Skyhigh/Knukonceptz/Rockford Fosgate wiring
More Coming Soon.. Check my builds below.
97 Civic Hatch Build
86 Caprice Build
you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion
Also be sure to do the big 3, Step that fuse up to a 300 amp since you would be running a 270 alt and the wire shouldn't be over 5ft or so. (Big 3 charge wire).
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
86 Caprice Build
Question about that. To get all technical, if you connect the smaller one to the bigger one, what happens with the current? Like if you crank it to start the car, does the power come from the bigger one, or both? And the alternator charges which? I get what you mean about how to wire them, just wondering about the technical aspect of it.
Sheena = pedobear
Well i would think the front battery would take most of the hit while turning on the car, Seeing as it is closer to the starter and will have more CCA (Cold Cranking Amps) then the smaller one.(if we are talking same brand) But basically when connecting them together they will act as one bigger battery. Not 100% sure but thats my theory.
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
86 Caprice Build
Also the alternator would charge up the front battery and that battery will charge up the other one, Now say you have a run to the front batt and a run to the back off of the alt, That should be a more efficient way of keeping them charged seeing as they will "split" the amperage.
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
86 Caprice Build
And then comes the question of if you have it like that, where does the power come from for everything? Would you run headlights, interior lights, tail lights and such off of one battery and system off another? I mean if you everything hooked to your front one, why would you need a run to the back battery from the alt? Most of the power would ultimately come from the front battery so you'd want most of the alt's effort on the front one. Unless I'm a giant noob and fail at mechanics, which can be possible.
Sheena = pedobear
Seeing as they are tied in together, It becomes one, so when one is struggling a little thats when the "backup" power comes into play and helps take a load off of the main batt.
Lets put it this way, I think in some years the Impala SS had a v8 that only fired 4 cylinders under a light load but when you needed those extra ponies while you were trying to Race/Pass/Climb hills, All you had to do was stomp on the gas and feel the awesome muscle of that v8. Essentially two engines becoming "one" to get the load stabilized.
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
86 Caprice Build
  • Who's Online   0 Members, 0 Anonymous, 1031 Guests (See full list)
