Box building tips.
MrEwubbsZ
So ive been reading for awhile now and im about to start a build but im still not completely sure how i should build the box I dont mean the size of the box or tuning i mean actually build the box. what should i use to put it all together?
wood glue
screws
1 1/2 inch doles
what im not sure about is what everyone uses in the cracks. It seems like liquid nails is what alot use but i dont know if that is the best thing.
Then i see some guys coat the inside of the box with resin. Should i do this? Anything to get it more strength?
I just need some tips to make sure i dont screw this box up.
Make good accurate cuts and all you need is wood glue and screws
Resin is a waste of time to me..for a daily system which it sounds like this is
If you have some small gaps just use silicone to seal it.up
Team Flex Issues
Alright so that all sounds about right? How should i do the baffle? Should i glue it first then Screw everything together? I dont want it to split apart and im not sure if it will do that. and i should glue it together then screw it before the glue drys?
Glue-clamp-drill.
There's a few box builds i've done recently in my sig. just for inspiration if you need it :)
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
also, don't use too many screws. Glue gives you strength. give about 5-6 inches between screws.
More box builds
  • Who's Online   0 Members, 0 Anonymous, 1746 Guests (See full list)
