Mikey Bates Posted August 24, 2012 Report Posted August 24, 2012 So when i get in my car my voltage usually 13.4-13.8 idle with no bass. and full tilt itll get down the the 12s. would charging my bat (stock) help for a little bit anyways? i do have big 3 btw. only puller 1200-1600 watts btw
SlamminBeats Posted August 24, 2012 Report Posted August 24, 2012 you just have voltage drop drop to the 12s man, charging the battery probably wont do much, especially if its a stock acid cell one. Just add one in the back to help witht the drop. Also an alt would do wonders..
Mikey Bates Posted August 24, 2012 Author Report Posted August 24, 2012 would adding like a d6500 up front instead help? and start with gettin rid of the acid bat? so is an alt still near in the future?
8ight Posted August 24, 2012 Report Posted August 24, 2012 would adding like a d6500 up front instead help? and start with gettin rid of the acid bat? so is an alt still near in the future? If your alt can't provide the amperage you pull your voltage will drop, period. I'm gonna hate
Mikey Bates Posted August 24, 2012 Author Report Posted August 24, 2012 yeah i guess i saw that coming haha. and is there any way to tell how much amps your amp pulls? that would tech be the fuse ration correct? or you could use that number?
SlamminBeats Posted August 24, 2012 Report Posted August 24, 2012 yes adding batteries helps, regardless of the alt. If the alt sucks, your batteries drain quicker. Ive ran 2k on big 3 before. I don't recommend it.
8ight Posted August 24, 2012 Report Posted August 24, 2012 yeah i guess i saw that coming haha. and is there any way to tell how much amps your amp pulls? that would tech be the fuse ration correct? or you could use that number? No you will need a clamp meter. I'm gonna hate
