Are Infinite Baffle Setups Any Good?
Have you checked your ceiling joist spacing? It's usually 16" on center. 18's won't fit without boxing the joists like you would for a large skylight, and you might get a lot of flex from the motion of the drivers if you skimp on the framing. Also, consider a hardware cloth cage in the attic to keep rodents from gnawing on everything.
Build a vertical "tunnel" which exits into the room below. Good for easy servicing and allows easy changes to the setup without redoing your ceiling every time.
Hammerdown... 1%
The biggest thing about an IB setup is the baffle, its all about the baffle. You want it thick enough to seperate the back of the speaker from the front in terms of vibration. The only reason an IB would ever sound bad is if it was designed poorly where the rear sound waves caused cancelation from the front.
