i have a 92 s10 with the 2.8. i just recently put a whole new clutch kit in it new disk, pressure plate, throw out bearing...everthing between the tansmission and motor. The problem i am having is that when running i cant get the truck into any gear it just wont go no mater how hard you push. I bench bled master cylinder and slave cylinder and reinstalled them and still nothing. anyone who can help?
Did you replace the slave?
Is it the correct clutch? I did a clitch and was sent the wrong kne 3 times ... Double check before installing I had to drop my trany 3 times in my cavalier..
Have someone get in truck and work the clutch see if you can watch the clitch seperate from flywheel
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
will it go into any gear when the truck is not running? If it goes into gear try to start the truck and if it trys to take off then you may have a master cylinder or slave cylinder problem. You may also have an issue with the clutch. But if it wont go into gear you probably have a transmission issue not a clutch problem.
Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born.
My penis is bigger than your penis
I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
with the truck off it shifts fine. If i put the truck into first gear then start the truck i can hear a harsh noise but the truck doesnt go anywhere just kinda creeps if you let off the brake.
May need a new slave, If i do a cluth I usualy do the slave as well
May sound stupid Buttt Did you put the throwout bearing on the right way?
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
It's hydrualic clutch? Did you adjust the clutch pedal with the new Clutch master. I had mine changed by a friend who also is an ASE mechanic while i was installing the clutch on my 240sx, and he forgot to adjust the pedal. Took me a day to figure it out. Got to make sure the pedal is adjusted far enough in to actually activate the pressure to release the hold of the pressure plate
