Well all my boxes are 14" tall and my opening is 14 1/4" tall, soo I'm good on that part, but I really dont wanna fuck up my car with expanding foam since I won't be using th box I currently have in my car cause it's ported to the passenger side. I'm gonna use my old 4th order that I had before my current one. I'm guessing just use some gorilla tape cause I don't plan on keeping it for more than a few days, just wanna compare it to not being sealed off.
Put down masking tape where the expanding foam will be, it works as a protective layer between the sealing walls and the car. I did it, and decided to not seal it after all and literally just pulled it all out and it's clean.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
How much does expanding foam fuck up your car? Can it be removed?
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
If you put it between the walls of your trunk and the cardboard/mdf that you're using to seal off and put a layer of masking tape under where the foam may possibly go, it won't fuck it up at all if you want to take it out some day. Just make sure that all surfaces of your trunk that the foam would otherwise touch is covered with the tape.
I got a pic. I'll upload it.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
You can see the tape on the sides. I put the tape on the side of the box as well.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
Ahhh thank you sir, box isn't as important to me since it's my shitty box (first time doing a 4th order) so it sounds pretty bad looking back on it now, but I'm gonna stick it in there and seal it off when I have some spare time and see how it compares to not being sealed off. Thanks for the info, I just didn't wanna destroy my trunk just for some testing.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
No problem, let us know how it turns out.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
will do, I'll post it up under my build log tomorrow when i have the time
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
  • Who's Online   0 Members, 0 Anonymous, 1046 Guests (See full list)
