RAY HELP! 06 BMW 750 Li amplifier install
I ca't find any wiring diagrams anywhere. Stock stereo.
I am helping a friend install an amp for a sub. He had a friend of his attempt to install it with no success (he actually fucked things up in the back, i would kill him if it were my car).
My main 2 questions are....
What should i wire the amp turn on button to? Or should I run a relay?
Without running a sound processor, is my only other option to run a line out converter for the signal?
I cant find anything online concerning an install in this car.
Any help is appreciated from someone who actually knows what they're talking about.
IMO the stereo sounds great stock with the factory subs but it's his car, not mine.
Thanks brahs
Eclipse cd7000
nothing?
I found the L7 (name of stock amplifier) amplifier in the back but I dont know which to tap into for a hi/low converter.
very frustrating!
Eclipse cd7000
Sounds like you need a multi meter!
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
There is full range speaker level at the back of the radio.
4ch
18awg white at deck or factory amp is the amp turn on wire.
Thanks Ray, you the man!
Chief....I was hoping to find signal in the trunk where the amp is to save time and wiring, however it's a very crammed space up in that left corner!
Eclipse cd7000
In a pinch or if hes cheap
The 12awg twisted pairs off of the factory amp are the 8's under the front seats.
Can hi-low there, and grab 18awg white for amp turn on.
  • Who's Online   0 Members, 0 Anonymous, 912 Guests (See full list)
