It's strange that GM didn't decide to fuse my lead wire from the alt to the battery, they must not have known what they were doing either. I don't fuse my BIG3 lead wire, nor have I ever. It's an extra break in the line and just ONE more thing to check for if things ever went wrong. I've never had issues with running non fused. I only run my fuse from the battery to the amps in the back . I DO however run a fused distrobution block to give each amp its necessary amperage that they like to pull.
Sorry if I am getting off topic, but just curious. Do you fuse the wire from front to back between the battery and distribution block, and then put another fuse between the block and each amp? Just trying to picture the setup in my head.
Here's my under good setup. Youll see the fuse leading to the firewall as well:
Inside the cab, there is a fused distro block with an 80 for the 4 channel and a 100 for the mono.
  • Who's Online   0 Members, 0 Anonymous, 912 Guests (See full list)
