Hello guys today i added a big 3 upgrade on my car using 4 ga wire, i did 2 runs from the alt to the battery and 1 run for ground power from the engine groun to the battery and two other runes from the cars body to the battery, is it safe to keep them without fuses? And if with fuses what ampere should i use?
You don't need to fuse, its for safety. Good for the piece of mind. A 150 amp fuse would be good for that wire.
edit:
Do it like this:
Alt to batt positive
Batt to ground
Engine block to ground
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
You should fuse the charge lead, since you ran two wires, you need to fuse each one. If at all possibe, you should run a single 1/0 instead of 2x 4ga.
In the best case scenarios, 4g awire can carry 150amps of current and 1/0 can carry 300amps.
What output is your alternator capable of? your fuse should be no greater than what the wire is capable of carrying, and no smaller than your alternators max output.
Can you post pics of your work?
edit:
Do it like this:
Batt to ground
Did you mean to say that you don't need to fuse? Bad advice if that's what you really meant.
You don't need to. A lot of people don't and I didn't say that I advise it. It's good for safety in case you get into an accident and it cuts the wire or the jacket melts on something.
B5 Passat Build Log
Here is how you really do it: start by using the largest size and best wire you can get. Make sure your soldering/crimping is done right, not just so so.
  • Add to, do not replace, the charge lead running from alternator to battery positive. Fuse this charge lead appropriately, unless you do not care about your car or anything electrical hooked up to it.
  • Battery negative to Chasis/Frame
  • Battery negative to engine block
Some people also run a ground wire from alternator casing to frame, not necessary but dosen't hurt.
Search this forum for big3 tutorials.
SMH.
op, believe what you want about fusing...
I will clarify what I mean by saying you NEED to fuse the charge lead..
Will it work without a fuse? Absolutely, asuming you hooked it up right to begin with. Adding a fuse can be a pain, and it isnt always convenient.
It is a safety measure to prevent fires, and damage to electric components in your vehicle. Many people do not charge their fuse lead, and never have a problem. Many people also often drive without wearing their seatbelts and never get into wrecks.
Fuse it or don't fuse it, it's your ride. Just know the risks you are taking either way.
  • Who's Online   0 Members, 0 Anonymous, 952 Guests (See full list)
