Amp question.
ClassicsWithSQ
stay far away from BOSS they overrate there amps alot. what is ur price range for an amp, an i can find u an amp that will push more then a boss amp will.
My build
98 s10 2.2
3 american bass HD 15s with psi soft parts. (on there way here)
atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build)
alpine 6.5s in doors
infinty 4x6s in dash.
clarion cz201 HU.
mechman 240a H/O alt
stuff i still need.
SHCA 2/0 wire
SHCA 1/0 to 2/0 adapters
Atomic AT-3000.1
Lots of sound deadner
new mids an highs, still debating on what to do.
A few Deka g31 batts.
how many 10's? im assuming 2?
My build
98 s10 2.2
clarion cz201 HU.
stuff i still need.
SHCA 2/0 wire
Atomic AT-3000.1
if your running 2 sa-10's this amp here will push them nicely. http://www.sonicelectronix.com/item_52884_MB-Quart-ONX1.1600D.html
that should b giving them about 800 each if u can run them at 1ohm.
or for 30 dollars less u could get this http://www.sonicelectronix.com/item_23875_MB-Quart-ONX1.1500D.html that would push about 750 to each @ 1ohm. an i kno sa-10 are rated @ 600 rms but im sure they will take 750-800 rms just fine.
My build
98 s10 2.2
clarion cz201 HU.
stuff i still need.
SHCA 2/0 wire
Atomic AT-3000.1
You can run this amp at 2 ohms and it will be just right for those subs. Hifionics brutuz puts out rated power.
http://www.sonicelectronix.com/item_23547_Hifonics-Brutus-BRZ1700.1D.html $200
MB Quart is decent too for the price. http://www.sonicelectronix.com/item_23875_MB-Quart-ONX1.1500D.html $170
In order to get 2 ohms wire the voice coils in series, and speakers parallel
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
whoops took too long to post, my bad. didnt see the other 2 ppl post
if your running 2 sa-10's this amp here will push them nicely. http://www.sonicelec...ONX1.1600D.html
or for 30 dollars less u could get this http://www.sonicelec...ONX1.1500D.html that would push about 750 to each @ 1ohm. an i kno sa-10 are rated @ 600 rms but im sure they will take 750-800 rms just fine.
He can't wire those subs to 1 ohm. Only .5 2 and 8.
or honestly u can check the for sale section an look an see what amps u can find in the 200 dollar range. i have seen some nice amps pretty cheap there.
My build
98 s10 2.2
clarion cz201 HU.
stuff i still need.
SHCA 2/0 wire
Atomic AT-3000.1
  • Who's Online   0 Members, 0 Anonymous, 1058 Guests (See full list)
