caraudiolove Posted September 8, 2012 Author Report Posted September 8, 2012 i think i got it this time got it exactly tuned to 33hrz
john253a Posted September 8, 2012 Report Posted September 8, 2012 how much power and clearance from the port opening to the nearest wall or restriction you no there only rated at 150rms in ported incloseres
caraudiolove Posted September 8, 2012 Author Report Posted September 8, 2012 800w max 14.4v and my voltage right now is 13.4v i dont know why my voltage is that low i have 2 battery's
Guest Posted September 8, 2012 Report Posted September 8, 2012 more batteries doesn't equal higher voltage.
john253a Posted September 8, 2012 Report Posted September 8, 2012 poof and smoke will be the first thing you see when you pop the trunk 3 times rated power, get a better sub rated at 150rms in 1.7-2.2cuft including sub displacment http://www.kicker.com/sites/default/files/2010%20Comp%20Multilingual%20e01.pdf you should have went the compVR and spent the extra $20
Guest Posted September 8, 2012 Report Posted September 8, 2012 poof and smoke will be the first thing you see when you pop the trunk 3 times rated power, get a better sub rated at 150rms in 1.7-2.2cuft including sub displacment http://www.kicker.co...lingual e01.pdf you should have went the compVR and spent the extra $20 he said 800w max, so 400rms. i think he should be fine.
john253a Posted September 8, 2012 Report Posted September 8, 2012 amp model would make that more clear 400rms his sweet, @ 4net but @ 800, his nice entry level, cheap setup just cost him twice what it should
caraudiolove Posted September 8, 2012 Author Report Posted September 8, 2012 so would that box be nice
