HELP WITH THE FILTERS ON THE AMP
IM HAVING TROUBLE UNDERSTANDING HOW THE LOW PASS, SUBSONIC, AND HIGH PASS FILTERS WORK ON A MONO BLOCK AMP SINCE ITS A SUB AMP WHICH FILTERS DO I USE AND WHATS A GOOD SETTING FOR THEM IM GOING TO BE LISTENING TO RAP MUSIC THAT HAS DEEP BASS.
WHATS SOME GOOD SETTINGS
2011 Impala
pioneer headunit
rockford fosgate rca's
audio control three.2
rockford fosgates T165&T1692
2 re audio sxx 15's
hifonics brz24001.d
crunch 1400.4
audio technix 10ga speaker wire & 0 ga power n ground
  1. DON'T USE ALL CAPS. IT IS THE FORUM EQUIVELANT TO YELLING.
  2. Tell us a bit about your box.
    1. Specifically your sub box. Sealed, vented or bandpass?
    2. Size of box
    3. if not sealed what is your tuning frequency?
    4. port dimensions
    5. if bandbass what are your chamber sizes
[*]What type and how many subs?
[*]What type of monoblock amp?
[*]What type of ride is this in?
Welcome to SMD.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
2 re audio sxx 15d4 @ 1ohm
hifonics brutus 24001.d 2400rms @1ohm
tahoe
box is going to be made by fatbox
2011 Impala
pioneer headunit
2 re audio sxx 15's
hifonics brz24001.d
crunch 1400.4
what type of box ?
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
The box has a big influence on how you should set your filters.
We need more info on it from your builder.
Eclipse cd7000
ported
2011 Impala
pioneer headunit
2 re audio sxx 15's
hifonics brz24001.d
crunch 1400.4
  • Who's Online   0 Members, 0 Anonymous, 949 Guests (See full list)
