SETTING MY SYSTEM UP FOR SUCCESS
ALL I WANT IS SOME CLEAN DEEP BASS AND SOME CLEAN AND CLEAR MIDS AND HIGHS NO DISTORTION
MY SYSTEM CONSIST
PIONEER HEAD UNIT
AUDIO CONTROL THREE.2 EQ
HIFONICS BRUTUS 2400.1D
2 RE AUDIO SXX 15D4
6 POWER ACOUSTICS NB.2 TWEETERS
BIG 3 UPGRADE
EXTRA BATTERY
STILL LOOKING FOR A GOOD 4CH AMP FOR THE TWEETERS
I DONT WANNA OVER WORK MY SUBS OR AMP I WANT EVERYTHING MATCHED RITE
2011 Impala
pioneer headunit
rockford fosgate rca's
audio control three.2
rockford fosgates T165&T1692
2 re audio sxx 15's
hifonics brz24001.d
crunch 1400.4
audio technix 10ga speaker wire & 0 ga power n ground
First, go easy on the caps.
Second, welcome to SMD.
I'm going to give you a really high level response to this at first and see where this goes. Please don't take offense as none is intended.
Seems you have two choices at the skill level I am going to assume you have (minimal).
  1. Pay a qualified installer to put your system together. Depending on where you are this may be a challenge.
  2. Do ALOT of reading and research on this forum and then start asking specific questions to suppliment your research.
You will want to start in the electronics section. The foundation of a clean system is the electrical support you provide it.
http://www.stevemeadedesigns.com/board/forum/12-electrical-battery-alternators-wiring/
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
http://www.stevemead...rnators-wiring/
x2. hooking up a system is very complicated. it will take TONS of research and questions. So best advice? find someone local to do it.
Sheena = pedobear
  • Who's Online   0 Members, 0 Anonymous, 949 Guests (See full list)
