12 Lvl 3 m2 15s w/ Lvl 4 coils.
12 lvl3 m2 15s with lvl 4 soft parts. Going in a 6th order bandpass, powered by 6 M3a's. Going to have 18 spv70s and 2 Singer 350A alts. Right now I've got 2 of the amps 9 of the batteries and 1 of the alts, along with all the subs. For finals I'll have 4 of the amps in. The shell is made of 2x2 1/4" thick steel. The loading wall is 6.5" thick and backed by steel the same steel as the cage on the top, bottom, and sides. The baffles are backed by steel as well. The real wall is 5.75" thick and also back by the steel in almost every 90 degree place. There is a drop roof where I had the steel welded to the top of the cage and right where my windshield is in the front. Right there I will put 2 layers of birch and foam all above that. That is to keep the pressure completely off my actual roof and have no flex with a strong secondary roof. On with the pictures.
Gol dam, dat sum serius bidnis mang!
2006 Cadillac Escalade
2/3 drop on 28" wheels
Two RE SX 18" subs
RF T2500-1bdCP amp, 3531watts on birthsheet
Custom carbon fiber sub box
EVERYTHING else is stock, for now
149.4 @ 37hz, Termlab, dash, open window on two AQ3 18s all stock electrical, wired to .25 ohm on a RF T2500
148.8 @ 36hz, Termlab, dash, open window on one AQ3 18 all stock electrical, wired to .5 ohm on a RF T2500
147.8 @ 38hz, Termlab, legal, sealed on two RE SX 18s
146.4 @ 36hz, Termlab, legal, sealed on one RE SX 18
Link to my hack-built, stupid, carbon fiber wasting project.... http://www.stevemeadedesigns.com/board/topic/149946-carbon-fiber-box-update-1494db-37hz-on-tl/
http://gifsoup.com/NDM3MTc1MQ
