1968 vw beetle build log. two skar ma-8s
Had ear2ear design me a box off specs that i gave. I got as close to his dimensions as i could considering they were into 32ths of a inch:) my saw, pencil led, and human errorplayed into some of it. Thanks for the help man. I may try a 4th order after i hear this but time will tell. 1.2cuft @ 34hrz.
View through back window
View from inside
Still have to cut holes and make the trim panel, and of course get the subs I bought on pre order;). Stay tuned, ill be updating this as i go
Cool - you knocked that out pretty quick!
It looks pretty good man...I see you made a couple changes.
Hope those subs come in soon.
'09 Sierra Ext Cab - under construction
(1) RF T2500-1 -running- (4) RF T1 12's
(1) RF T1000-4 -running- (2) RF T1652-S
Stock alt / battery -plus- (1) DC Power 230a & (2) Kinetik 1800
Buncha OFC Knu
Buncha Second Skin
Kenwood DDX814 - Alpine Imprint - RF 360.3
I did screw up a bit so I tryed saving as much wood as possible, hence the back not dropping all the way down. I hope it sounds good with two little 8s. I may do a small fiberglass top/pods on the top to add a little more cuft, like I said, I screwed up a bit:( But I cant thank you enough. I need to figure out how to figure up port displacement better...
