Building my own 3 way, please critique!
79Bronco
I understand impedance does not change on a bridged setup. It is bridged to draw more power since the drivers are 8 ohm.
I was under the impression that crossovers do not greatly affect the impedance seen by the amp. I thought their only job was to split up frequency. Why, in this case, does the crossover all of a sudden have a huge impact on the nominal impedance seen by the amp?
Source: Parrot Asteroid Smart
Processor: Digital Designs X1
Amps: Soundstream Ref 4.920 + Soundstream Ref 4.400 + Soundstream DTR 3400
Front stage: Hertz 165xl + HL 70 + HT28
Rear fill: Hertz 165xl
Subs: 2 SA-12's
3-way active ftw
It's not an all of a sudden change. Have you ever bought a component set bnib and measured the impedance of each speaker individually? You can have 2 4 ohm speakers connected to a passive xover and the amp "sees" 4 om still.
You can read up on it here: http://www.diyaudio.com/forums/car-audio/147511-component-speakers-impedance-values.html
You can read up on it here: http://www.diyaudio....nce-values.html
:facepalm:
Yes I understand this.
I have two 8 ohm speakers.
Amp should see an 8 ohm load, correct?
The way I read your post made it seem like the crossovers would have an effect on the nominal impedance seen by the amp.
Subs: 2 SA-12's
3-way active ftw
so 8 ohms nominal?
and yes this setup will work?
:deadhorse: lol
Subs: 2 SA-12's
3-way active ftw
Funky, I think I get what you are trying to say. I understand that the impedance seen by the amplifier is constantly changing as music is sent to the speakers. I understand that by introducing a passive crossover, the goal is to make the impedance much higher at lower frequencies for the tweet and much higher at higher frequencies for the mid. By making the impedance exponentially high, the hope is that the signal roll-off will be so great, that there will be little to no reproduction of undesired frequencies.
Is that what you're trying to get at?
The only reason I am asking for nominal load is because I want to know, realistically, what kind of amplifier to start looking for.
Subs: 2 SA-12's
3-way active ftw
Bump, would like to order everything tomorrow.
Subs: 2 SA-12's
3-way active ftw
Speakers and crossovers have arrived. I'll be returning them all. I've decided to just go fully active instead.
Swapping out the nd105-8 for the 4 ohm version, will be looking for different tweeters as well.
Also looking for advice on an active crossover. If I can get away with just running the one built into the amp, I'd be much happier than shelling out 100-300 for an external.
Subs: 2 SA-12's
3-way active ftw
Here's the new plan.
Amp is a Soundstream 6 channel.
Components are
Cadence Tweet
Dayton Mid
Beyma Woofer
Subs: 2 SA-12's
3-way active ftw
  • Who's Online   1 Member, 0 Anonymous, 1120 Guests (See full list)
