79Bronco Posted September 11, 2012 Report Posted September 11, 2012 Howdy SMD forum I'm going to try to make this as to-the-point as I can. I am going to replace the front stage in my 2010 Jetta. I am using factory speaker locations. Speaker sizes are 1", 4", and 8". I will be adding plenty of deadener to the doors. Head unit is a Pioneer 4400. RCA's tested 40/40 no clipping on flat EQ. It has an 8 band EQ. For the 1" and 4", I want to get a 2-way component set with a passive xover. This will go to the "A-channel" on my 4 channel amplifier. I will set the crossover to high pass and cut frequency appropriately. For the 8", I will be using only the xover on the "B-channel" of my amp. Setting low pass frequencies appropriately. The H/U only has 4 sets of preouts (not including sub). I will get a Y-adapter for the RCA's so that I can effectively run my front stage off of just the first set of preouts. Rear stage will come at a later date, hence not using the second set. ------------------------------------------------------------------------------- Cliffs notes ------------------------------------------------------------------------------- Pioneer 4400. 40/40 no clipping 8 band EQ (2x) 1" + 4" 2- way component set w/ passive xover (2x) 8" midbass driver (1x) 4 channel amplifier 2 channel rear to come later Does anyone see a problem with this? I do not want to go active since it's $$$, but I feel that this can be a good solution to a nice 3 way system. It never hurts to get a second set of eyes on my schematics, so please feel free to rip me a new one. Thanks! Source: Parrot Asteroid Smart Processor: Digital Designs X1 Amps: Soundstream Ref 4.920 + Soundstream Ref 4.400 + Soundstream DTR 3400 Front stage: Hertz 165xl + HL 70 + HT28 Rear fill: Hertz 165xl Subs: 2 SA-12's 3-way active ftw
Scynte Posted September 11, 2012 Report Posted September 11, 2012 Just out of curiousity, what amp are you planning on using? Depending on the amp you will use you might be able to get rid of the passive xover. Reason being is 2-way comp speakers are designed to cover the frequencies down to around where the sub will fall off (around 80-100 hertz I beleive depending on the speakers). So it would kind of make the 8" a bit pointless. Where as if you get rid of the passive xover, you could control the frequencies that each speakers see giving you a bit more control especially if you want to use an 8" with the comp set.. just a thought either way.
79Bronco Posted September 11, 2012 Author Report Posted September 11, 2012 I have not picked out a specific amp yet. My rationale behind using the passive x-overs is that they come with the 2-way component kit. Could you explain more about how it would be possible to eliminate the xovers? I have seen most 4" drivers play down to around 100hz (not that I plan on running them that low), but most tweeters would play to around 3k Hz. It seems like a crossover would be needed. Source: Parrot Asteroid Smart Processor: Digital Designs X1 Amps: Soundstream Ref 4.920 + Soundstream Ref 4.400 + Soundstream DTR 3400 Front stage: Hertz 165xl + HL 70 + HT28 Rear fill: Hertz 165xl Subs: 2 SA-12's 3-way active ftw
mrd6 Posted September 11, 2012 Report Posted September 11, 2012 I would try to find an amp that has crossovers built in (I think that is what scynte is talking about). Also if you go this route it opens up the option of buying single drivers rather than a set. If you decide to do this I would recommend this tweeter: http://www.madisoundspeakerstore.com/lpg-soft-dome-tweeters/lpg-25nfa-1-textile-dome-tweeter-neodymium-magnet/ It is my favorite sounding tweeter to date and will play well down to about a 3k crossover point like you described My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
79Bronco Posted September 11, 2012 Author Report Posted September 11, 2012 What Im getting at, is how would it be possible to cross over frequencies on one channel to two different speakers. I dont want to send a 300hz tone to my tweet, and I dont want to limit my 4" to only 3khz and up. Source: Parrot Asteroid Smart Processor: Digital Designs X1 Amps: Soundstream Ref 4.920 + Soundstream Ref 4.400 + Soundstream DTR 3400 Front stage: Hertz 165xl + HL 70 + HT28 Rear fill: Hertz 165xl Subs: 2 SA-12's 3-way active ftw
Ray Posted September 11, 2012 Report Posted September 11, 2012 You are on the right track Highpass Passive to mid tweet Lowpass active to the mid bass But also set highpass at 50-60 on the deck Focal, hertz, hybrid all make A nice 3 way set that will fit your needs. Go with nice speakers and throw some power at it. 150 per side should be just fine. 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
BobbyG2 Posted September 11, 2012 Report Posted September 11, 2012 If I ever get around to building some speakers for my home/computer, I'll be doing it with Dayton components in a 3-way. Tweet - http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=275-140&scqty=4 Mid - http://www.parts-express.com/pe/showdetl.cfm?Partnumber=285-020 Woofer - http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-376 *New vehicle and system coming soon.*
79Bronco Posted September 11, 2012 Author Report Posted September 11, 2012 Ray, thanks for the helpful reply. BobbyG, no offense but your post has absolutely nothing to do with my OP. Source: Parrot Asteroid Smart Processor: Digital Designs X1 Amps: Soundstream Ref 4.920 + Soundstream Ref 4.400 + Soundstream DTR 3400 Front stage: Hertz 165xl + HL 70 + HT28 Rear fill: Hertz 165xl Subs: 2 SA-12's 3-way active ftw
BobbyG2 Posted September 13, 2012 Report Posted September 13, 2012 Was just a suggestion for the components of the 3 way *New vehicle and system coming soon.*
Guest Posted September 13, 2012 Report Posted September 13, 2012 hope you're not gonna be running the square kicker woofers, judging on the square subwoofers drawn in the picture.
