CodyLucente Posted September 11, 2012 Report Posted September 11, 2012 Ok, hi everyone. I am running 2 Power Accoustik MOFO's 12". I am having trouble finding a good amp to run them. They claim 1500w rms each. My subs are 2ohm DVC. I cant decide on what amp to use on my build. Plz do not start bashing the brands i have chosen. this is a budget build. I am also open to any other options you have but keep in mind Budget is a KEY factor. Also, i can swap my subs for 4ohm DVC if you have 1ohm recommendations. In short, i need your help. Alpine 2400w rms 2ohm - http://www.alpine-us...t/view/mrx-m240 450$ Power Accoustik BAMF 5500 (CLAIMS 2300w rms 2ohm) 210$ Power Accoustik D1-6000D (CLAIMS 2800w rms 2ohm) 210$ Sound Stream 2600w rms 0.5ohm - http://www.soundstre...-tarantula.html 360$ Subs= SoundQubed HDC3.112 Amps= Audio Technix1200.1, Sony XM4x40 & Clarion XC1410 Rear= Pioneer 6"x9" coaxial Front= Polk 6 1/4 componants Trunk Lid= Pioneer 6 1/4 coaxil Battery= Optima Yellow-top (front) Shrunken 35AH Wire= 0/2 AWG welding Cable! Alternator= 125amps Extra= Continuous duty solenoid
mikeg321 Posted September 11, 2012 Report Posted September 11, 2012 Out of those choices the Alpine would be your best bet Edit: you could always run one of these at 1ohm http://store.crescendoaudio.com/bc2000d/ it's a little cheaper than the alpine and will do about the same power. 4 fully loaded Fi sp4 15's 2 Crescendo bc5500s Crescendo c1100.4 6 focal mids Vifa tweets 5 XS Power d3100's Pioneer avh-p4200dvd All crammed into a mustang. http://www.stevemeadedesigns.com/board/topic/150569-mikeg321s-fi-nendo-mustang-getting-walled-videos-page-4/
CodyLucente Posted September 12, 2012 Author Report Posted September 12, 2012 That is a nice amp!! It said 0.5 ohm compatible with a "strong electrical" i am running 14.4 volts thanks to my 8 ferrad cap and my 2 yellow-tops. now it caps off at 16.8v so i guess that means to run 0.5ohm i would need a 16volt system? Subs= SoundQubed HDC3.112 Amps= Audio Technix1200.1, Sony XM4x40 & Clarion XC1410 Rear= Pioneer 6"x9" coaxial Front= Polk 6 1/4 componants Trunk Lid= Pioneer 6 1/4 coaxil Battery= Optima Yellow-top (front) Shrunken 35AH Wire= 0/2 AWG welding Cable! Alternator= 125amps Extra= Continuous duty solenoid
Ray Posted September 12, 2012 Report Posted September 12, 2012 Alpine. 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
mikeg321 Posted September 12, 2012 Report Posted September 12, 2012 No you can run it at .5ohm on 14.4 volts BUT you'd need roughly double the electrical to run it at that load vs 1ohm. IMO the stress on the amp and electrical system isn't worth the couple hundred extra watts you'll get from running at .5ohm, if your chasing tenths on the meter it might be worth it but for daily stick to 1ohm. Edit: Ray has spoken. If your going to take advice from anybody on this forum he's the guy to take it from. 4 fully loaded Fi sp4 15's 2 Crescendo bc5500s Crescendo c1100.4 6 focal mids Vifa tweets 5 XS Power d3100's Pioneer avh-p4200dvd All crammed into a mustang. http://www.stevemeadedesigns.com/board/topic/150569-mikeg321s-fi-nendo-mustang-getting-walled-videos-page-4/
CodyLucente Posted September 12, 2012 Author Report Posted September 12, 2012 I am not to knowledgeable when it comes to the effects of low impedance on systems other than the higher the ohms the more "clarity" you should get out of your speakers and that at a lower resistance you can get more power out of an amp. I never knew it put that strain on my electrical. thanks that is actually very helpful. ALSO i know the alpine is the pest choice however as stated price is a concern so if anyone has a cheaper alternative. Subs= SoundQubed HDC3.112 Amps= Audio Technix1200.1, Sony XM4x40 & Clarion XC1410 Rear= Pioneer 6"x9" coaxial Front= Polk 6 1/4 componants Trunk Lid= Pioneer 6 1/4 coaxil Battery= Optima Yellow-top (front) Shrunken 35AH Wire= 0/2 AWG welding Cable! Alternator= 125amps Extra= Continuous duty solenoid
STL.Don Posted September 12, 2012 Report Posted September 12, 2012 Well I wouldn't use any of those because you would be under powering your subs which is harmful. I would look at maybe an AudioPipe 3000+ watt rms amp or two AudioPipe amps that are 1500+ watts rms each. Now i am saying AudioPipe because they are pretty inexpensive for what you get. Now if you want to get extremely good quality I would look at DC Audio (or Sound Lab, whatever it truly is), but you will be paying for the quality, not sure how much, but not cheap. But if you want to power your subs properly I would do two amps and wire them to power each sub. That's what I am doing so I know that each sub is powered, but maybe look at one 3000 watt rms amp first and see if you could swing it. You would not be disappointed.
Jessica Posted September 12, 2012 Report Posted September 12, 2012 Well I wouldn't use any of those because you would be under powering your subs which is harmful. I would look at maybe an AudioPipe 3000+ watt rms amp or two AudioPipe amps that are 1500+ watts rms each. Now i am saying AudioPipe because they are pretty inexpensive for what you get. Now if you want to get extremely good quality I would look at DC Audio (or Sound Lab, whatever it truly is), but you will be paying for the quality, not sure how much, but not cheap. But if you want to power your subs properly I would do two amps and wire them to power each sub. That's what I am doing so I know that each sub is powered, but maybe look at one 3000 watt rms amp first and see if you could swing it. You would not be disappointed. Underpowering wont hurt anything. ever listen to your stereo at less than full volume? underpowering and compensating by cranking the gains and clipping is harmful. I hate car audio myths. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
STL.Don Posted September 12, 2012 Report Posted September 12, 2012 Well I wouldn't use any of those because you would be under powering your subs which is harmful. I would look at maybe an AudioPipe 3000+ watt rms amp or two AudioPipe amps that are 1500+ watts rms each. Now i am saying AudioPipe because they are pretty inexpensive for what you get. Now if you want to get extremely good quality I would look at DC Audio (or Sound Lab, whatever it truly is), but you will be paying for the quality, not sure how much, but not cheap. But if you want to power your subs properly I would do two amps and wire them to power each sub. That's what I am doing so I know that each sub is powered, but maybe look at one 3000 watt rms amp first and see if you could swing it. You would not be disappointed. Underpowering wont hurt anything. ever listen to your stereo at less than full volume? underpowering and compensating by cranking the gains and clipping is harmful. I hate car audio myths. That is what guys with 12+ years each of experience in this industry have told me. Now I am going with what they have said because they have never directed me wrong since I have been dealing with them.
Omega5002 Posted September 12, 2012 Report Posted September 12, 2012 Well I wouldn't use any of those because you would be under powering your subs which is harmful. I would look at maybe an AudioPipe 3000+ watt rms amp or two AudioPipe amps that are 1500+ watts rms each. Now i am saying AudioPipe because they are pretty inexpensive for what you get. Now if you want to get extremely good quality I would look at DC Audio (or Sound Lab, whatever it truly is), but you will be paying for the quality, not sure how much, but not cheap. But if you want to power your subs properly I would do two amps and wire them to power each sub. That's what I am doing so I know that each sub is powered, but maybe look at one 3000 watt rms amp first and see if you could swing it. You would not be disappointed. Underpowering wont hurt anything. ever listen to your stereo at less than full volume? underpowering and compensating by cranking the gains and clipping is harmful. I hate car audio myths. That is what guys with 12+ years each of experience in this industry have told me. Now I am going with what they have said because they have never directed me wrong since I have been dealing with them. Just cause someone been doing something wrong for 12 years doesn't make them right. I encountered a guy with "30 years experience" saying that ported boxes destroys subs, which is blasphemy. Plus, they probably been clipping if they kept blowing super powerful subs with tiny amps. Underpowering doesn't hurt anything 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
