CleanSierra Posted September 13, 2012 Report Posted September 13, 2012 Don't play below tuning, don't play below Fs fully cranked on volume. You also never told me what coil configuration your subs are on. If you've got Dual 2s and you're wired at 1 ohm, you've got too much power going to it. How much port are you feeding the sub. Box dimensions would be helpful. Port dimensions are also needed. There are a few things it could be. Quick glance points its finger at playing below tuning. It COULD be port noise I suppose if you don't have enough port area per foot. Im not the one you want to try to troll. Just a fyi for you.
CleanSierra Posted September 13, 2012 Report Posted September 13, 2012 If you're feeding monster power to a sub with an Fs if 34, and you're playing it at 28 Hz, there's a good likelihood that you're jumping the coil out if the magnetic gap. Stop doing that or you'll destroy the sub. Im not the one you want to try to troll. Just a fyi for you.
kogwanted Posted September 13, 2012 Author Report Posted September 13, 2012 When does this sound occur? On the really low notes? It it's a tone below Fs of the sub, the coil could be jumping the gap. What coil configuration is the sub? Is it a dual 4 or a dual 2? dual 4
