Hey all i recently came up on 2 orion hcca's 12.4. I went to orion directly to chexk the specs for a ported box enclosure for one of this bitches. And NO FUCKIN WAY it says it only needs 1.5 cubic ft tuned to 40 hertz. Is that true?
If you are going by their spec, that's for if you are running above 2000 watts
So anything below that would require a smaller box?
Another quick qquestion these are the newest black models, if i baught the older silver model of craigslist would it offset the soynd?
If you have less power you need a bigger box. And its best to have them both be the same models
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
Another question, since my subs are dual 4 ohm. What amp can give me 2000 watts rms at 2 ohm.. yea yea i kno why not get a 4000 watt amp to 1 ohm. Nah i think 2 2000 watt amps look nicer in overall instal looks
Try the 'generic' 12s box. 2.25 per sub @ 33hz with ~60sqin of port
How much power you running?
  • Who's Online   0 Members, 0 Anonymous, 1204 Guests (See full list)
