HC3400BLK Posted November 7, 2006 Report Posted November 7, 2006 how to wire a cap up to a sec battery or jus to one battery pics web sites diagrams all needed ASAP thanks :-[ Quote 2 12" Kicker cvx1 proacoustic 4 now either quantum audio amp r Ma audio nextKenwood dash4 gauge wire pioneer in the doorsjvc in the back
ChevyBoy Posted November 7, 2006 Report Posted November 7, 2006 QUIT POSTING UP DIFFERENT POSTS!! U GOT LIKE 3 ALREADY, SO WAIT FOR AN ANSWER! Quote
Ernesto Posted November 7, 2006 Report Posted November 7, 2006 QUIT POSTING UP DIFFERENT POSTS!! U GOT LIKE 3 ALREADY, SO WAIT FOR AN ANSWER! LOL > Quote
HC3400BLK Posted November 8, 2006 Author Report Posted November 8, 2006 my bad dude i jus need 2 know how to do it n plus i posted it in the wrong sec at first :- Quote 2 12" Kicker cvx1 proacoustic 4 now either quantum audio amp r Ma audio nextKenwood dash4 gauge wire pioneer in the doorsjvc in the back
Guest MegaloManiac Posted November 8, 2006 Report Posted November 8, 2006 I told you, wire the second battery in parralel with the other battery and for the cap all you do is cut the power wire in half and post 1 end on 1 side and the other on the other side Quote
mrwigglezdj Posted November 8, 2006 Report Posted November 8, 2006 parrale means to put the positive + from the first battery to the positive + of the second battery and then the ground - goes to the the body of the car, and for the cap like he said you simply put a positive wire from the cap to the battery + and a ground from the cap to the body of the car but you have to charge the cap first it should come with a little thingie that you connect to charge Quote Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
Guest MegaloManiac Posted November 8, 2006 Report Posted November 8, 2006 wouldnt that be series? pos to pos on batt? for paralel shouldnt it be + from 1st bat to - on 2nd batt? and then use - on 2nd batt for + and use the + on 2nd batt as ground? Quote
mrwigglezdj Posted November 8, 2006 Report Posted November 8, 2006 lol well im not sure im confused now but if you do pos of one battery to the negative of the other battery that would create a 24 volt load Quote Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
Guest MegaloManiac Posted November 8, 2006 Report Posted November 8, 2006 i think you're right. i got confused. cause me and a couple of friends wire up some 2 modded kinetik2400 and 2 regular kinetik2400 into 16v, we wired it in series-paralel. the modded kinetiks had a 4v bank and an 8v bank on the same batt Quote
HC3400BLK Posted November 8, 2006 Author Report Posted November 8, 2006 ok thanks i ready 2 start installing now Quote 2 12" Kicker cvx1 proacoustic 4 now either quantum audio amp r Ma audio nextKenwood dash4 gauge wire pioneer in the doorsjvc in the back
