Ian.251 Posted September 15, 2012 Author Report Posted September 15, 2012 As in a piece of wood in each corner of the box?
Raptorman Posted September 15, 2012 Report Posted September 15, 2012 Those are 45's. You want to use wooden dowel cylinders going from top to bottom and from side to side. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Raptorman Posted September 15, 2012 Report Posted September 15, 2012 Once you get bracing, make sure you add that into the calculator so it doesnt throw off the tuning you're tryin' to shoot for. I don't know the formula to find the volume of the cylinders, sadly. Hopefully someone can chime in and clarify. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Ian.251 Posted September 15, 2012 Author Report Posted September 15, 2012 Well this is the first speaker box I'm building "the right way". So I have no clue how to do the either. And im using 7.5 cf and the specs say max 4 and min3
Joe X Posted September 16, 2012 Report Posted September 16, 2012 Ok here is a suggestion within kicker spec and your max dims: Enclosure Specifications: Fb = 36 Hz Vb = 8 ft^3 External Height = 20 in External Width = 42 in External Depth = 24 in Port Width = 5 1/2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Top & Bottom = 42 x 24 Left & Right Sides = 22 1/2 x 18 1/2 2x Front = 18 1/4 x 18 1/2 Back = 42 x 18 1/2 Shared Port Internal Assembly Parts: 2 x Front to Back = 14 9/16 x 18 1/2 45s are 2.5 wide. You can use it or learn Torres with it.
Ian.251 Posted September 16, 2012 Author Report Posted September 16, 2012 Is there just one port down the middle. Or is there also 2 ports on the bottom? And in your personal opinion. Will it beat harder with subs facing up. Or facing out the same side with the port
Joe X Posted September 16, 2012 Report Posted September 16, 2012 Is there just one port down the middle. Or is there also 2 ports on the bottom? And in your personal opinion. Will it beat harder with subs facing up. Or facing out the same side with the port What you see below are two optional 45s placed horizontally, there is a single port is in the center, Subs up/port back (as shown) is the most used configuration for your type of vehicle and regarded as best for loudness in most cases.
Ian.251 Posted September 16, 2012 Author Report Posted September 16, 2012 Okay thank you so much you were a really big help
Ian.251 Posted September 16, 2012 Author Report Posted September 16, 2012 I've seen a lot of ported boxes with the port and it is L shaped. And the one you came up for me doesn't is there a reason most ported boxes have L shaped ports?
