Cruze2 Posted September 18, 2012 Report Posted September 18, 2012 Hello guys I am in need of some good advice, I am currently saving up for a new system, and it will consist of two PSI 10 inch subwoofers both at a dual 2 ohm load, and they both will be hooked up to separate amps. The amps I am pairing them with will be sundown saz2500d wired down to one ohm. So I will be hoping to push about 5k watts daily. I am going to get a yellow top optima for under the hood, not for sure which model i would need. I drive a 2012 Chevy Cruze 1LT with the pioneer upgraded sound system. The batteries I am going to put in the trunk will be xs power d3400's, I am putting two in there, not for sure if it is correct. So I was wondering if I should get an ho alt. and get the a yellow top optima and would I be fine with the two d3400's in the rear? Please help me out it would be greatly appreciated if anyone could. Thank you for reading this. 2012 Chevrolet Cruze
Mikey Bates Posted September 18, 2012 Report Posted September 18, 2012 put the biggest xs bat under the hood. to my understanding there are two yellow tops though. they are the same battery one just has side posts... btw sounds like a sweet build!
Blackedout Posted September 18, 2012 Report Posted September 18, 2012 No go on the optima. Xs power front and back. 3 group 34s 65' ofc 1/0 (1 run power, 1 run ground, big 3) Minimum of 3 fuses. This will be fine for daily. If you are competing, the story changes. Trunk Build Log
Cruze2 Posted September 19, 2012 Author Report Posted September 19, 2012 thank you so much for the help guy i really appreciate it, lol so would i be fine with replacing the hood bat with an xs power and then 3 3400s in the trunk, and i wouldnt need to replace the stock alt? I am starting to get more into car audio now, and i am looking for as much help as possible from experienced audio enthusiasts like you it helps a lot really lol 2012 Chevrolet Cruze
