Need some help!
i doubt it's that good, but if it fits, i think a chilton's manual would show you how to install it.
92 previa LE dual sunroof lunarwagon
saz-1500d v.3
2xsa-15, self-made ported enclosure tuned to 35hz
rockford all other
xspower batts, mechman 240a s-series single alt
Ok. thanks
I need help, First off, is this a good alt for a Chevy 1998 k1500 ex cab: http://tiny.cc/91j0kw . And how would I go about installing it?
It depends on what type of performance you expect out of it. What type of system are you running or planning on running? Often these cheaper ebay alts that advertise higher than stock amperage achieve that amperage rating by making trade offs. What I mean is you will loose output at idle (significantly) to get that peak rating- often at a high RPM. They also tend to use cheap parts - made in the usa or not cheap is still cheap.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   0 Members, 0 Anonymous, 2066 Guests (See full list)
