ChevyBoy95 Posted September 30, 2012 Report Posted September 30, 2012 the small piece the makes the L is 3 and 3/16ths reason being is because i measure the port length from the middle including at the triangle in the middle. like this (thin line is the middle of the port) Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
revoracing247 Posted September 30, 2012 Report Posted September 30, 2012 how long is yours if you go from center of the middle channel to the end of the L part? and just out of curiosity, can you think the 6.5" wide middle port as the two separate ports coming and running side by side with nothing separating them? cause i notice your line to measure the length of the center port is like 1/4 away from the wall, which would be the middle of the left side port if you think of it as the way i said above sorry if that's confusing, i think in my own ways some times. ~ If it was easy, everybody would be doing it ~
ChevyBoy95 Posted September 30, 2012 Report Posted September 30, 2012 how long is yours if you go from center of the middle channel to the end of the L part? and just out of curiosity, can you think the 6.5" wide middle port as the two separate ports coming and running side by side with nothing separating them? cause i notice your line to measure the length of the center port is like 1/4 away from the wall, which would be the middle of the left side port if you think of it as the way i said above sorry if that's confusing, i think in my own ways some times. cant understand half of this, rethink it, and explain a little more clearly. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
ChevyBoy95 Posted September 30, 2012 Report Posted September 30, 2012 Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
revoracing247 Posted September 30, 2012 Report Posted September 30, 2012 haha sorry! i guess im asking why you have the line down the middle on the L part but to one side down the center part. ~ If it was easy, everybody would be doing it ~
revoracing247 Posted September 30, 2012 Report Posted September 30, 2012 just wondering if you took the measurement wrong some how. cause 3 3/16 would be bottle necking it some. but it looks fine in your other pic ~ If it was easy, everybody would be doing it ~
ChevyBoy95 Posted September 30, 2012 Report Posted September 30, 2012 haha sorry! i guess im asking why you have the line down the middle on the L part but to one side down the center part. because theoretically, if you split the 6.5 down the middle, you have 2 3.25in ports (which is what you have when the cambers are separate i.e. Ting off). that is why i did it so close to the side. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
revoracing247 Posted September 30, 2012 Report Posted September 30, 2012 haha sorry! i guess im asking why you have the line down the middle on the L part but to one side down the center part. because theoretically, if you split the 6.5 down the middle, you have 2 3.25in ports (which is what you have when the cambers are separate i.e. Ting off). that is why i did it so close to the side. aahhhh! there, that's what i was trying to ask haha thanks ~ If it was easy, everybody would be doing it ~
