Removable Port Calculations?
i believe sometime in march im gonna be workin on a new system. 2 15" Fi Bl's in a 7 cube box in the trunk of a civic.
i wanted to make it musical and really nail the lows but i also didnt want to limit him to just music. so my question is how do i calculate wut size each port needs to be. or really just tell me everything there is to know about these ports
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
first off, are u able to calculate tuning and port displacement?
if you can then it shouldnt be a problem...
its just a matter of knowing the volume of ur enclosure after sub displacment. then just figure up the size of the port u want and subtract its displacement from the volume and find the tuning.....just do that for each port...not much different than any normal tuning...there is just no end correction most the time since swappable ports usually dont use a box wall as part of the port wall....
i likes me some audio stuff...
wut do u mean by they dont use a box wall as part of the port wall?
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
like a slot port for instance...more often than not a slot port is on one side or the other of the enclosure and uses a box wall as a port wall, whereas a actual square port for example...like meade's...has four sides to it and doesnt use a box wall as part of the port, therefore there is no end correction calculation...make sense?
ok i get it.
can u test my calc with ur calc to see if its correct?
7.5 cubic foot box
30hz= 18h x 5w x 28.1d
40hz= 18h x 5w x 12.38d
are those right?
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
