Kenyel Dotts Posted October 1, 2012 Report Posted October 1, 2012 Trying to hook up a second alt. I do not want to hook it up to my factory set up because of alarms. is it possible to hook up a external voltage regulater that will charge my bat with out over charging on a daily drive. King dingalingIts not finished till i say so Bit@^!
Kenyel Dotts Posted October 1, 2012 Author Report Posted October 1, 2012 must add that the primary alt is a 220 and i also want this unit to charge my bats also. I need about 500 amps of power and i only want to add 1 d3100 and a d3400. Any good ideas will help. Will i need more bat juice? King dingalingIts not finished till i say so Bit@^!
Miguels Posted October 1, 2012 Report Posted October 1, 2012 wait what? just because you have high out put alts it dont mean they will overcharge a battery. alternators already have a voltage regulator and it wont charge past the set voltage the alternator will throw more amps as your system needs it. though the voltage will remain the same unless the system demands more amperage my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Kenyel Dotts Posted October 1, 2012 Author Report Posted October 1, 2012 Ok even though it has one internal what is the Pont of every connector other then the positive terminal on a alt? King dingalingIts not finished till i say so Bit@^!
Kenyel Dotts Posted October 5, 2012 Author Report Posted October 5, 2012 no one King dingalingIts not finished till i say so Bit@^!
Guest Posted October 5, 2012 Report Posted October 5, 2012 you want two alts separate from each other, but charging the same batteries? HUH? you're confusing as fuck. the point of the 1/2/3/4 wire plug that goes into the side of the alt, is so the car can control and monitor the alt.
Guest Posted October 5, 2012 Report Posted October 5, 2012 how can a second alt cause the alarm to go off? thats impossible. the alarm isn't active when the car is on...
Kenyel Dotts Posted October 7, 2012 Author Report Posted October 7, 2012 you want two alts separate from each other, but charging the same batteries? HUH? you're confusing as fuck. the point of the 1/2/3/4 wire plug that goes into the side of the alt, is so the car can control and monitor the alt. Ok..... If i hook up the 1234 wires to control both ats it will set off a alarm ( not a aftermarket alarm a warning alarm on the dash) telling me that their is some thing is wrong I dont want this light to turn on so i cannot connect the two to the car 1/2/3/4 plug. But i still want to run 500 amp system with two alts. the point of the 1/2/3/4 wire plug that goes into the side of the alt, is so the car can control and monitor the alt. wait what? just because you have high out put alts it dont mean they will overcharge a battery. alternators already have a voltage regulator and it wont charge past the set voltage ok explain King dingalingIts not finished till i say so Bit@^!
Kenyel Dotts Posted March 1, 2013 Author Report Posted March 1, 2013 stuck are we? King dingalingIts not finished till i say so Bit@^!
