Newbie Box Building Question....
uhh... this may be off subject but, are those zebra boots? or zebra duct tape?
Team Audio Specialists
1998 GMC Sierra SLT Z71 ext. cab
Headunit: Pioneer DEH-P7400HD
Mids and Highs:
One pair Boston SC65 6.5s
One pair Boston SE75 4x6s
Two pairs of Precision power T.2 tweeters
Two pairs of ebay type tweeters (soon to be replaced)
Boston GTA704 four channel amp
RCAs: Stinger 4000 series 4 channel RCAs
Lows:
Two Sundown Audio SA-12s
Sundown Audio Saz-2500d
3.9 cubic foot ported box (full 45 corners) fully braced and resined tuned at 33hz, all before displacement
XS Power D3400 and Interstate starting battery, both under hood
all KnuKonceptz Kolossus 1/0 wire (just 1 run for now)
Big 3 done in 1/0
Audio Specialists <-----Best car audio shop in Western Kentucky/North Central Tennessee
Yeah those boots are pretty cute.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
I think people tune between 50 and 60hz for 4th orders. If the fs is in the 40's the it may have trouble with the lows but mid 30s and up it should do fine. and yeah 15 sqin of port PER cube ft, is what you are looking for. so about 30 sq inch for you box.
That would be Zebra Duck Tape. ;-) Again, its my ladys sub box!
Im looking for zebra Trollhair for the top inside of the box, so the hair flows with the bass
Thats what i was thinking!
  • 3 weeks later...
OK so a new port has been installed, the plexi has been glued in better and I have more mounting screws holding the front panel on. Along with about 5' of Campers foam tape between the panel and the box.... And the boy does it boom!!
I have been running an MTX5601 wired to 1 ohm (for some reason it has never got warm) Gain is on less than half and I'm flexing the baffle between the sealed and ported chambers the subs are mounted into. haha. damn. So I will be bracing the center up.
But I'm still hearing what sounds like the sub box flexing.... at first i though it was the subs bottoming out... but i realized the sounds isn't coming out of the port, its coming from the back of the box somewhere...
No way a box made from 3/4 MDF is flexing from 2 10's at 350rms.... any ideas?
maybe noise from it not sealing around the plexi maybe?
Driving my 2008 Dodge Ram 2500 MEGA cab with the 5.7 hemi.
Audio: Two 10" Alpine Type R's ( 1000rms models )
Hifonics BRZ 2400.1D @ .5 ohm
Two Kinetic 1400 batteries ( soon to have XS power under hood )
Tsunami 1/0 Awg wire throughout truck.
Stock Infinity 7 speaker system ( Junk ) soon to be replaced, probably all Alpine.
Exterior: 17"Dick cepek rims with 33" Toyo MT tires
Bushwacker fender flares
Magnaflow true duel exhaust
LED tail lights with Projector headlights
Plasti-dip fun coming soon!
also picked up a new amp.
RF250.2
250 RMS per channel at 4 ohms,
Well these subs are single 2 ohms coils, so ill be putting about 375 RMS to them. or much cleaner power than the MTX.
Nolte told me that these are 400rms all day long so that should be perfect!
This sounds similar to my box. I started out with those aero ports and decided to get rid of them and go to a rectangular port. Sounds way better. My box is also flexing and tearing itself apart. 2 12's on about 1000 watts. It's 3/4 Mdf and the outside has quite a bit of resin and body filler. If I were you, just use mat and resin to strengthen up that baffle. Maybe even some dowel bracing. That's what I'm looking at doing. Good luck man and keep us updated on what you do.
  • Who's Online   0 Members, 0 Anonymous, 771 Guests (See full list)
