Newbie Box Building Question....
My Buddy and i Just built our first 4th order, and it didnt turn out how we wanted...
The box is for 2 Nolte Audio 10's, and it going into a 97 Honda Accord Sedan. The box was purely a Sound Quality Intention... And SQ it does have. The notes are crisp, and clean, and keep up with the Fastest of notes... they are just really quiet!
It is honestly not half as loud as they were when they were in a pre-fab ported box, tuned to the 550's
Ill post up a sketch-up when i get to my other computer, but the box is 1 cub + polyfill Sealed with 0 sub displacement. (subs mounted face down)
and 2.1ish cubes ported tuned to 55hz.
The box has a removable face so it makes getting to the sub easy. I took the face off and it got exponentially louder. Now i haven't calculated the "port" aka, the access hole to see what that would be tuned too... But here is my question
The box is tuned to 55 using a 4" areo Port, not is it possible that the port, even tho its tuned properly, is still tuned too small to allow for optimum volume?
Im still new to everything, and i hope this makes since without pix!
Thanks in Advance!!!!!!!!
Now when that front panel is removed, they get much louder than with it on.
And when i use the panel as a slider door, with it half open, it is the loudest... So im assuming i need a larger port opening, so do i need a larger/longer port to allow more air to excape while keeping the tuning the same?
Dont mind the crudness of the box, it is nowhere finished, the body will be carpeted to match the trunk, the face will be painted a purple with Black/white splater paint to match the subs.
Yup, going to be cutting out the areo port, and replacing it with a vertical rectangle port.... Any advise?? I'm still confused, so I'm just going with instinct.
sorry i can't be any more advice, as i've never built a 4th order. but just wanted to say that i like the whole plexi window to look at the baskets and magnets. pretty cool, and from what it looks like a bigger port would be better. personally i've never liked round ports but then again i've never bought a true aero port.
i say if you have the materials and time then mess around with it!
~ If it was easy, everybody would be doing it ~
After alot of research, i have found that everyone says 15 Sq In of port is ideal for each cubic foot of ported box.
So i will be cutting in a port approximately 5x6x7 That will keep the tuning around 60 Hz
Most people tune their 4th orders to around the high 40's. Also, it's like 14-18 sq In of port per cube for slot ports, Aero ports are around 9-13.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
your suffocating your subs...there is pretty much no way that the aeroport you are using is tuning the box to 55hz
maybe give your dimensions of the 2 chamber and the size of the current port for people to try and trouble shoot for you, maybe then someone can recommend a new port that would perform better
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
Sorry, Im not using the areo anymore.
Its being cut out of a 5x6 Square Port, in place of the areo. The port will the 2.25 long inside and 4" long external. Giving it 7" of port length
  • Who's Online   0 Members, 0 Anonymous, 928 Guests (See full list)
