mrd6 Posted April 9, 2014 Report Posted April 9, 2014 Yessss You should bring it to lowdown at the end of July, its definitely one of the most fun shows we have all year My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
revoracing247 Posted April 10, 2014 Author Report Posted April 10, 2014 Yessss You should bring it to lowdown at the end of July, its definitely one of the most fun shows we have all year im totally down. is that at SoundWerks? ~ If it was easy, everybody would be doing it ~
mrd6 Posted April 10, 2014 Report Posted April 10, 2014 It's at a fair grounds or something in centralia the audio comp is part of the mini truck show and everyone camps there all weekend. Was a 4x weekend last year if I remember right. My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
revoracing247 Posted April 27, 2014 Author Report Posted April 27, 2014 It's at a fair grounds or something in centralia the audio comp is part of the mini truck show and everyone camps there all weekend. Was a 4x weekend last year if I remember right. im totally down. just hope i can get my truck as done as i want by then was able to put some more time into the T-line today! while on break and back home between semesters i was able to get some materials for the box building (and some left over from previous projects) let the fun begin! so first thing was first. getting the huge kerfed boards glued in when i glued these i put glue along the edge and then quickly ran a bead down each kerf and then put it in place. here's the first board taken off to glue and then there wasn't much too it so here's them being glued in place. i put a ton of weight on because non of the kerfs are screwed in or else it'd split the wood so i just put a ton of weight on it while it glued. next was getting the small other pieces put in. i debated having the port fanning out as it exits the box (ie not putting in those two pieces to square it off) but after thinking about it it'd raise my tuning even more and ruin a lot of the response of the t-line. so i put them even though it wont look as cool :/ ~ If it was easy, everybody would be doing it ~
revoracing247 Posted April 27, 2014 Author Report Posted April 27, 2014 alright so next if getting ready to do the fiberglass. so first a little bit of bondo work here's the 3 edges i need to fill in before i can fiberglass. the closed end of the t-line where the port straightens out to exit the box and then the first baffle. i just want to make this one smooth so that there's good adhesion when i put on the second baffle. mmmm fresh bondo.....it's been a while i was only able to get get the first coat on the one that is on the first baffle but she's comin along. i was thinking of incorporating plexi somewhere in the box. $200 is too much to do the whole front so any suggestions from you guys? ~ If it was easy, everybody would be doing it ~
revoracing247 Posted April 28, 2014 Author Report Posted April 28, 2014 got all the pre-fiberglass bondo work done. here's what i got to. but first. nice day outside mixing time! and then here's the three spots all done. next time i make it out there to work on the box it's gonna be sanding and fiberglassss!!! ~ If it was easy, everybody would be doing it ~
thefourth Posted April 28, 2014 Report Posted April 28, 2014 I just fell in love Thanks alaskanzx5 I might just do thatI can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream. oh lawd.
revoracing247 Posted April 28, 2014 Author Report Posted April 28, 2014 I just fell in love thanks man! glad there's people enjoying my work. ~ If it was easy, everybody would be doing it ~
revoracing247 Posted April 28, 2014 Author Report Posted April 28, 2014 here's a video for you guys it's with the current ported box ~ If it was easy, everybody would be doing it ~
REVOofRustler Posted April 28, 2014 Report Posted April 28, 2014 Its lookin good! 2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant - Fi and Crescendo - Stock Bose System - http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota 136.4 Sealed @ 29hz 137.0 Drivers window open @ 26hz
