Need Help With a box choice.....PLZ
Nao
Need some experienced help on a box decision. I have a 18 inch sub im building a 6 cuft box with aeroports @ 30-31hz its a trunk build going in a 2004 Honda Accord. I know certain setups sound different in different environments but from some experienced persons in trunk builds what sounds best and is loudest and also kill the lows.
1) Sub and port forward sealed off from the trunk
2) Sub up port back/front
3) Sub forward sealed off and port side/back
sub forward port forward, sealed off, is almost always loudest in trunks. you just have to make sure you sealed every single hole on/around the rear deck. if not, you will be louder with the trunk open than closed. sounds weird, but thats how it works.
aw ok RAM DESIGNS was designing a box for me and he was saying sub forward sealed off port back or side whats the purpose of that i thought the reason for ports other than tuning is the sound to escape out it making the setup louder. how loud would it be with this type design
i wouldnt seal off if the woofer and port are on different planes.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
So doing both sub and port forward sealed is my best option? Also the sub is a soundstream xxx 18 6cuft @ 30-31hz tune how many aero ports and size you think is optimal
i hgihly doubt you are going to have the height to fire an 18 forward or abck in a trunk car.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
I have a height of 19 1/4 max that to the 6x9 magnet so i can squeeze it in or i can build the box in the trunk wider and further behind the magnet and have a clearance of 23.5 inch but that would make it more difficult to seal off
  • Who's Online   1 Member, 0 Anonymous, 1347 Guests (See full list)
