Box size for 2 18" Re sx 18's.
Brandon15zzz
Alright I bought 2 18" re sx subs with fi soft parts from a friend. They have direct leads, 5 spiders. There supposed to be built for spl. Atleast that's what fi wrote on the coil lol. But I need help with how much space i should put them in. My buddy told me as big as possible which would be around 12 cubes after displacements staying below window line. Then other people have told me no more then 5 cubes for each. This build is more for music then burping and doing numbers. Ill be running these on a crescendo bc2k at .7. Ill probably be running 2 10" ports with them.
So basically I just need people's opinion on how many cubes I need for them on the 2k of power.
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
Up
The REs are recommended to be in 8 cubic feet per sub net for optimal use. Not sure how the FI soft parts affects the specs? I'm pretty sure that is for a max SPL application. I have two RE SX 18s in a box that nets 10.6 cubic feet, so 5.3 cubes per sub. It slams hard and plays all sorts of music, even metal, really well. It even hits the lows reasonably well. But IMHO, it could be a bit bigger. The subs never seem to extend fully even under full amplifier power above their rated load. I believe thats because the box is on the small side. If I made a new box, I would probably go about 6-6.5 cubes per sub, for a nice compromise between musical response and SPL. I took one sub out of the box and capped the hole, netting appox. 10.9 cubic feet for a single RE SX 18 and it is definitely waaaay too big of a box. At 1860 clamped watts and too big of a box, it would only be a matter of time before the sub would give out on me if I kept it in such a large box. I can smell it getting hot after just a few minutes of loud play. I would say don't go smaller than 6 cubes per sub or larger than 8 cubes per sub. You'll like these subs though, they are a nice sounding piece.
2006 Cadillac Escalade
2/3 drop on 28" wheels
Two RE SX 18" subs
RF T2500-1bdCP amp, 3531watts on birthsheet
Custom carbon fiber sub box
EVERYTHING else is stock, for now
149.4 @ 37hz, Termlab, dash, open window on two AQ3 18s all stock electrical, wired to .25 ohm on a RF T2500
148.8 @ 36hz, Termlab, dash, open window on one AQ3 18 all stock electrical, wired to .5 ohm on a RF T2500
147.8 @ 38hz, Termlab, legal, sealed on two RE SX 18s
146.4 @ 36hz, Termlab, legal, sealed on one RE SX 18
Link to my hack-built, stupid, carbon fiber wasting project.... http://www.stevemeadedesigns.com/board/topic/149946-carbon-fiber-box-update-1494db-37hz-on-tl/
http://gifsoup.com/NDM3MTc1MQ
Thanks for the reply. Looks like ill put them the biggest box I can which should be around 12-14 cubes.
  • Who's Online   1 Member, 0 Anonymous, 661 Guests (See full list)
