CDetty Posted October 4, 2012 Report Posted October 4, 2012 Long story short, I'm just wondering if I will need to upgrade my alternator. I'm planning on a 1500 watt amplifier. Will I need a high output alternator after the Big 3 and upgraded battery? Edit: Standard alternator is 85 amps I believe. 1999 Honda Civic- RIP 2003 Acura RSX Type-S
MrClean636 Posted October 4, 2012 Report Posted October 4, 2012 Depends on battery. A H/O is never a bad thing to consider, especially if you plan on upgrading things later. A stock alternator is meant to just power the car. Should be okay on voltage with a 1500w amp and an upgraded battery (in the back I'm guessing? bc thats what you should be talking about lol) Car: 2011 Ford Taurus SEL / Alt: DC Power 270XP (Will be here 7/17!!!) Deck: Pioneer AVIC-Z140BH / Amps: (1) DC 5.0k, (1) RF T400-2 Speaks: RF T2652-S 6.5" and RF T1692 6x9" Subs: (2) DC XLm2 15's / Batts: (2) XS XP3000's Wiring: Kolossus Fleks Kable 1/0 (2 runs)
Nao Posted October 4, 2012 Report Posted October 4, 2012 I had a 2000 watt rms amp with 2 12s i did the big 3 had a kinetik 2400 in the back and a optima red top up front and voltage never dropped below 13.8v lights never dim even with a/c full blast and HIDs on so i dnt think soo
bumonskateboard6 Posted October 4, 2012 Report Posted October 4, 2012 Depends a lot on what company makes the 1500w amplifier as well... Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
finkster Posted October 4, 2012 Report Posted October 4, 2012 85 amps is rough..... I'd upgrade. What amp are you running? DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
Landon75 Posted October 4, 2012 Report Posted October 4, 2012 I'd say just have a couple decent batteries 1 up front one in back with some 0 gauge with good grounds and you should be fine. Just get a charger cause you always want to have you batts resting at a decent voltage.
