10 year old Forrester, sealed box with amp rack
Rockford P3 12", 1.4 cubes sealed. Hertz HDP5 pushing Hertz Hi Energy speakers. Very nice.
The pallette
Going to try to keep the jack storage
Layup was decent, but lumpy as all hell. There were a bunch of chunks of hard resin in my old pail..... The spout hardened up, and I had to break it all apart. I didn't think to strain it out.....
Tuani Fabrication
Wasilla, AK
Setting up the lines
How do you cut a circle through 1-1/2" of MDF with only a 1" bit?
Took some fancy footwork to get the amp in that close to the sub. Plus the help of this little guy...... and a bunch of duraglass to clean up the gaps....
And now, the giant router bit.
Tuani Fabrication
Wasilla, AK
Glad you like it
going old school. Never actually used this method before. I doubt I ever will again, but it is sure better than stretching fleece to a glass edge and awkwardly trying to CA glue it.....
big mess......
Tuani Fabrication
Wasilla, AK
Here's the trim
first layers had no dye, so I can see the sharpie lines.
Bolted in place.
Tuani Fabrication
Wasilla, AK
Tweeter pods made from stock ABS trim, sintra rings, CA, duraglass, and rage extreme.
Speaker baffles. How some 'high end' shops can avoid 'custom' work is beyond me. You CANNOT install a speaker correctly in a lot of vehicles out there without some setup to make rings like these.
these are also Sintra, 2 layers of 1/2" stacked. Notice the single-bearing-riding-on-2-surfaces-trick...
These rings were made in 20 minutes with a jig saw, router, an air saw, and an old ring hanging on the shelf that fit this speaker.
not 3m tape....
Tuani Fabrication
Wasilla, AK
I should have done this in 3/4"..... would have saved a bunch of blocking...
fine tuning the fit
the foam was all temporary, just for shape. All gone now. I have a little hole in the enclosure to fill.
My trim is THICK. I hate wimpy glass parts, and nothing could be worse than a customer pulling out the trim, dropping it, and having a chunk break off. 1/4" of glass
Tuani Fabrication
Wasilla, AK
I had this bright idea to do a double bevel. We'll see if it ends up looking any good...
Poly Primer
Tuani Fabrication
Wasilla, AK
sealing everything up, and blacking it out
This is the view from my shop, just the other night
Tuani Fabrication
Wasilla, AK
  • Who's Online   1 Member, 0 Anonymous, 577 Guests (See full list)
