(4) Zv3 12s - 5k - Project Nasty No wall
pretty sure you would get louder if you go with .25 or .5 ohms non strapped per amp, but i guess you can´t do it since the subs are D4 i assume
No I can do .25 per amp non-strapped. And I plan on testing that as well. Maybe not today, but I will
oh ok that´s perfect, let me know when you test that, i definitely got louder non strapped :)
check my last post. I fucked up. Input rca's on one amp are now trash and I can't test that anymore. SO. I guess I definitely will be going a different direction with amps when season gets in swing
1999 Ford ExplorerTeam Sundown Audio4th 2012 Db Drag WF Street Stock 150.8dbYoutube Channel!http://www.youtube.com/user/BoomyurblownOperation 156 No wall Build Log!http://www.stevemead...x/#entry2196123
Sucks that the RCAs got fouled up. Crap happens though. Even if 153 isn't where you wanted to be, it's still damn good in my book!
I'll be running my 1500s the same way, strapped at 2Ω. I may or may not make it to any comps so I probably won't run .5Ω strapped.
I might try gain matching at 1Ω though to see if it is louder.
Where do you usually compete? Most of the comps that are closest to me are in OH, but if there's something good going on in Maryland
I might have to check that out too.
2005 Subaru Outback Wagon Pioneer 9400BH Fi Q 15, SAZ1500dV3
The first build>>> http://www.stevemead...-outback-build/
140.9 @ 36hz Sealed on dash!
REBUILT!!! 2 Fi Q 15s, 2 SAZ1500dv3 146.9 @ 39hz dBDRA certified
Spanish motherfucker lol, i didnt understood almost anything, the wire broke and you need to replace it? the tip of the wire broke inside the amplifier? man i hate my english sometimes!
that rca problem is an easy fix, if the rcas are like the older amps, if there are 2 sets right next to each other, just open it up and switch the plugs on the amp. wont be strappable after it, but will let you test them unstrapped
after looking at a pic of your amp, you should be able to do that and still be able to strap it. youll just lose that output set of rca's which you probably dont use anyway.
Well I go to school at Purdue In indiana. So I'm out here from august through april. Most shows out here I go to are in the Indy area.
Rca cable got pulled from around the side of the amp. The RCA pins broke off in the amp. I got them out, but when they pulled from the side it created slop inside the plugs themselves so the input is never consistent with something plugged into it. Waiting for a buddy of mine to see if he can find a new set of iinputs and I'm just going to have it fixed.
I could do that, yes, but I will be trading these in in a few months so I want to retain all the funcitonality
Looking good man. That NS spider is probably hurting you right now.
I think that may be the case as well. A) for the fact they are NS spiders, and B) that the soft parts are very well used. Guy that owned it before me had 2500 per sub or so on music in a wall and did bassboxing for a full season with them
On a side note, Did some testing today. Was doing most testing at 2 ohm strapped. Found 4 tenths at that ohm load. Went to .5 strapped and couldnt get the same gain. Got it up to a 53.43. Rise is very low and amps can barely get a full burp off. To be honest I dont even know if they are. Also, I came to realize soon after that one of the hatch glass hinges is now stripped out so the glass was flopping around. Probably another reason why score was down a bit. I think with a charge, And a new hinge, it will do a 153.6 or so how it sits.
When I get a new hinge, I have another thing or two to try with the amps, and then It's in the box. Also am going to try to test an NS-1 at .5 to see how it compares to the 2 2500s strapped at .5
should get way louder with the NS-1 at .5 ohms!! you are using 1.5 c/f per sub right?
  • Who's Online   0 Members, 0 Anonymous, 1816 Guests (See full list)
