Pierre-luc Gagnon Posted October 13, 2012 Report Posted October 13, 2012 Hello these are picture of a professionaly done setup with acoustic treatement it is my system i have done many high end setup like this i have been doing this for over 10 years now the accoustic treatement started during the custruction with an accoustic floor it consisted of 1 inch of foam 1 inch of air in bettwen the foam and the plywood wich where connected together using a piece of wood of 1 inch it was also secured using tapcon every 6 inches drilled in the cement also the floor does not touch the walls it as a gap to minimize vibration true out the room the room is double dry walled with about a screw every 3 inch keep in mind i was setting up the system wen i took these so alot as changed i now have treatment in bettwen the back of the chairs to the rear wall where there was a reflection point also another think to keep in mind the treatment wasnt just trown on the room was measure at many point then i evaluated the room repsons and did treatment according to the problematic frequency loocking at the frequency response and the watter plot falls for decay time you will see surounds besides the rack in the back these where just temporary solution and you will also noticed that the front where angled in on there tripod i was listeening for soundstage the setup is as follow DHC-80.3 oppo bdp 95 with the sabre dac adcom gfa 7807 Pictured replaced with wyred for sound MC7x500 runing in 4 ohm @ 1100 watts rms x7 front speakers are 7 jtr triple 8 ht its not a coax its a compression driver that uses a midrange as a wave guide very very dynamic! subs is 2 Captivator 2011 with the 4000 watts rms amps in them (7200 burst) each projector benQ dlp w6000 pictured the bracket ripped from the bass and it fell! replaced with epson 8500 with a chiefe mount that is sitting on 2 laminated hdf piece of wood screwed in directly to the floor joice lol! i can see the image vibrate some time but it as not fallen yet we also did a custom electrical job in this we have a panel of 100 amp going to this room and it is grounded to the cold water pipe for a pitch black backround very important since my mains are 98db effiecency with 1 watt! all in all its a great system i lost count of how mutch money i put in this id rather not sit down and sum it up lol i did a recent come back in car audio i spent like 12 hr a day in my truck so i could not live with cheap sound we are doing a sql setup i will start a new post in the ride section! idlew1ld the French Frog !
severancej Posted October 17, 2012 Report Posted October 17, 2012 Ohhh...what the f.....? Now thats a home theater!!! 98' dodge ram 140A alt Big 3 XS D2700 JVC kd-r310 Rockford T500-1BDCP 2 Sundown E12 Ported 4cubes 35hz Rockford P400-4 2 Infinity reference 3way 6x9 2 Polk DB 5 1/4 2x layer dynamat all doors
Pierre-luc Gagnon Posted October 17, 2012 Author Report Posted October 17, 2012 Thatnks ! I put alot of time and money into doign it I build one wen i was learning and re did it all i also studied this many years to aquire the proper knowledge For constructin a room like that and accoustic property of material It as incredible extension amazing controle and the soundstage is amazing idlew1ld the French Frog !
knowledge Posted October 17, 2012 Report Posted October 17, 2012 got damn it thats nice. i almost bought some KEF blade towers the other day but damn it that price tag is up there REFF'SMy linkEBAYhttp://feedback.ebay...ck&myworld=trueI love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
Pierre-luc Gagnon Posted October 17, 2012 Author Report Posted October 17, 2012 Honestly knowledge i heard some of the most high end kef in the last few years They make a nice speaker but i would not look into home audio i i where you Most of these high end speakers are very low efficency and what that does it it removes alot of the dynamic Present in the music because they compress You cannot hear a speaker compressing and it is just a down side of such a design (small driver & low efficency) Keep in mind that the dynamics of a system is the second thing Most important After the tonality and it is the factor that Is making you beleive that ur right there in the music If you are going to spend that kind of oney I would look into jbl systhesis array 1400 model or some jtr stuff or even danley lab If u have adequate space for them Keep in mind most of these speaker will need some sort of eqing done in a regular home enviroment But imo if you decide to put the effort in it the end result is amazing ! idlew1ld the French Frog !
knowledge Posted October 18, 2012 Report Posted October 18, 2012 great info man ill look into the ones u mentioned REFF'SMy linkEBAYhttp://feedback.ebay...ck&myworld=trueI love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
Pierre-luc Gagnon Posted October 18, 2012 Author Report Posted October 18, 2012 Wen i oisten full tilt at reference level u cannot hear it out side iam using double walls with air gap in bettwen the and 2 insulation with roxul safe and Sound idlew1ld the French Frog !
Pierre-luc Gagnon Posted October 18, 2012 Author Report Posted October 18, 2012 Sorry dbl post idlew1ld the French Frog !
Omega5002 Posted October 18, 2012 Report Posted October 18, 2012 Very impressive setup, movies and video games must be epic on it 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
Pierre-luc Gagnon Posted October 18, 2012 Author Report Posted October 18, 2012 What is nice about his is it double as a dedicated theater room and a dedicated music room I have a flat setting to be used in movie since the movie industry all use the x curve compensation directly in there mix And i have a setting eq for music with a house curve in it because they are no set standard for mix in the music industrie The thing about having a setup like this is once you live the experince u are ruined for life! You cant live without it and now that iam doing a sql setup in my truck it is getting out of hand And i want nothing but something close to that It ends up beign a very big project i will post picture of my sql setup soon! idlew1ld the French Frog !
