Monte Carlo intermittent window power
sorry if this is in the wrong section. didnt know where to put it under the car section.
got a 99 monte carlo (replaced the corolla). the driver side window works like 70% of the time. sometimes the window will start to roll up fine, but then it will stop. itll start working again like five minutes later.
any ideas?
Weak motor, loose or bad connection maybe, my old furd would do the similar.
  • pa-pa-platypus
  • sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
My accord has this problem except that it has gotten way worse lately. I have spent hours with a multimeter, chasing the crazy ass wiring. It has a relay that does the whole auto down, plus a switch that de-activates the passenger side controls plus wiring for the passenger side control. I have ran jumper wires and and other things and have narrowed my issue down to one bad connection in the plug that connects the door panel wiring to the actual door wiring. If i squeeze the wires really tight right at the plug the window works every time. So Not that your car is the same as mine but that is where i would start, right at that connector. Then if that don't help, do like azagoth said and start looking at the motor and relays.
hmm....well i just ordered a new switch so hopefully that will fix it. if not, i have to spend $95 on a motor and regulator.
when i pulled the existing switch out, all the wires appeared to be in good condition. but i know that even if something looks good, it could still be bad internally.
my brother just texted me back and said that the driver side motor was replaced a few years back. im still thinking the switch. and if that doesnt work, then i'll definitely take a look at the wires/plug.
Well, I know you are a pretty smart guy, but unplug the harness and use your ohm setting on your multimeter and test to see if it works. You ought to be able to tell which wires go to which switch. Mine was a bit weird as the wire that went to the bottom of the switch was power in, and the middle and top tabs/wires were power out.
Its the switch. My friend and my moms fiance both have '00 and '01 monte's. Both of their window switches on driver side went bad. I thought it was pretty funny. Both cars are having the issues about a month or so ahead of one another.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
yeah? fucking chevy haha. the auto down feature on the existing switch doesn't even work, which kind of made me nudge even more towards the switch being bad.
