DJ Ground Pounding System
Hey everyone I wanted to ask your advice.
I been the car audio scene for many years had window smashing bass RE XXX 18”s FI BTL 18”’s and currently doing a full custom 2 door Tahoe with 4 18” SMD’s with a stock floor body drop on 24”s
Here is what I wanted the advice on.
I am a DJ/ producer does everything from weddings to corporate events to raves and major EDM events. Some need hard hitting bass and I listen to the sound these locations have and am like WOW seriously my truck hits way harder than this.
Yes I know diversity and not everyone wants hard hitting bass yes I agree but here is what I am getting at even the TOP name brands like right now QSC has the KW series love them great sound but still don’t hit as hard as the Cerwin Vegas 18” subs they no longer make.
Here are the specs of the KW Here is link for video and other info below… I found a company that is trying to convince those to replace the stock speakers with their hyped up speakers they have more wattage but looks like an old school rca speaker with small mag lol http://www.eminence.com/ they also do custom work and do car audio they claim I never heard them so I don’t want to knock anything but by looks unsure but ya never know…
http://www.qscaudio....cifications.php
Does anyone think it would be worth it to build a ground pounding system that is able to throw the sound the distance and not break my back in the process that would woop the KW’s
Series
SPECIFICATIONS
KW122
KW152
KW153
Configuration
12" 2-way multipurpose
15" 2-way trapezoidal
15" 3-way trapezoidal
Transducers
Low-frequency
Mid-frequency
High-frequency
12" cone transducer
1.75" diaphragm compression driver
15" cone transducer
15" cone transducer
6.5" mid range cone transducer
Frequency Response (-6 dB)
53 Hz - 18 kHz
47 Hz - 18 kHz
35 Hz - 18 kHz
Frequency Range (-10 dB)
50 Hz - 20 kHz
44 Hz - 20 kHz
33 Hz - 20 kHz
Nominal Coverage (-6 dB)
75° axisymmetric
60° axisymmetric
75° axisymmetric
Maximum SPL1
131 dB peak
133 dB peak
134 dB peak
Amplifier
Power Output2
1000 W Class D (500 W LF, 500 W HF) continuous
2000 W peak
1000 W Class D (500 W LF, 500 W MF/HF) continuous
2000 W peak
Input Impedance (ohms)
Channel A XLR / ¼":
Mic gain setting
Balanced
Unbalanced
0 dB
38k
19k
+12 dB
10k
5k
+24 dB
2.66k
1.33k
+36 dB
660 ohms
330 ohms
Channel B XLR / ¼": 38k balanced / 19k unbalanced
Channel B RCA: 10k
Controls
Power, Gain A, Gain B, Channel A Input Gain (0 dB / 12 dB / 24 dB / 36 dB), LF Mode (Ext Sub/Norm/DEEP™), HF Mode (Flat/Vocal Boost), Front LED (On/Off/Limit)
Indicators
Power, Signal A, Signal B, Standby, Limit, Mic (24 dB and 36 dB settings)
Connectors
Balanced female XLR/¼" line/mic level input, Balanced female XLR/¼" line level input, Dual Balanced male XLR full range line level out , Balanced male XLR "mix" out, Stereo RCA line level input, Remote gain control, Locking IEC power connector
Cooling
On demand, 50 mm variable speed fan
Amplifier Protection
Thermal limiting, output overcurrent, overtemperature muting, GuardRail™
Transducer Protection
Thermal limiting, excursion limiting
AC Power Input
Universal power supply 100-240 VAC, 50 - 60 Hz
AC Power Consumption
(1/8 Power)
100 VAC, 2.3 A
120 VAC, 2.01 A
230 VAC, 1.13 A
Enclosure
Material
15 mm painted birch plywood
Finish
Black textured paint
Grille
Black powder coated 16 gauge steel
Dimensions (HWD)
26" x 15" x 15.4"
660 mm x 381 mm x 391 mm
32.1" x 17.5" x 15.2"
816 mm x 445 mm x 386 mm
43.1" x 18.5" x 16.8"
1094 mm x 470 mm x 427 mm
Weight (Net)
49 lb (22.2 kg)
64 lb (29 kg)
87 lb (39.5 kg)
Available Accessories
KW SUS KIT 122, KW122 COVER, KW M10 KIT
KW152 COVER, KW M10 KIT
KW153 COVER, KW M10 KIT
KW Series
SPECIFICATIONS
KW181
Configuration
18" subwoofer
Transducer
18" cone transducer
38 Hz - 124 Hz
34 Hz - 143 Hz
Maximum SPL1
135 dB peak
Amplifiers
Power Output2
1000 W Class D continuous
2000 W peak
Controls
Power, Gain, LF Mode (Normal/DEEP™), Polarity (Normal/Reverse), Front LED (On/Off/Limit)
Indicators
Power, Signal, Standby, Limit
Connectors
Dual balanced female XLR/¼" line level input, Dual Balanced male XLR full range line level out, Remote gain control, Locking IEC power connector
Cooling
AC Power Input
Universal power supply 100 - 240 VAC, 50 - 60 Hz
(1/8 Power)
100 VAC, 2.3 A
120 VAC, 2.01 A
230 VAC, 1.13 A
Enclosure
Material
Finish
Grille
Rugged Powder-Coated Steel Grille
Dimensions (HWD)
20.1" x 23.4" x 29.9" with casters
510 mm x 595 mm x 761 mm with casters
Weight (Net)
88 lb (40 kg)
KW181 COVER
1999 - 2Door Chevy Tahoe
Kenwood KVT 915-DVD II 15” RE XXX (Fi Recone) II Components/ Center channel: Seas Audio, ScanSpea&k Dayton Reference II
Amp’s: Xtant – 603 & 1001 Chipped & Tuned II
Misc. Team PowerMaster Batt Cell, Xstatic 2000 Batcap, Street wires Zero Oxygen RCA Cables, 0 Gauge through out II Security Clifford Intelliguard 770
depends how much $$ you got. the qsc stuff is very nice and will get loud. How big of events are you doing/wanting to do. But I dont think you will be able to make some that will be as light and preform just as well. What qsc boxes are you looking at? I know iceman on here is in the works of getting 4 181's and 2 153's per side with a bunch of monitors.
PSN: Rcp_soundz
Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at.
I'll stick a 300 amp fuse in a potato and sell it to you for $2k.
1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
Try 4 KW153's and 8 KW181's (and it's only 6 monitors, plus my EV's) lol.
But as he said, as far as consumer equipment goes, QSC's K series tops and KW series tops and subs are excellent quality. I have heard of a couple DJ's using subs from JTR Audio (namely the Growler subs and the like) for a lot of low end bass. But as far as "buy now, get in 3 days" type gear, for powered gear, the QSC KW is well known in the wedding DJ world, and also has a 6 year no questions asked warranty. Anything more than that is going to be passive, and there are a ton of options (the JBL SRX series comes to mind, one of the most well known audio setups)
But in the world of powered sub-100lb speakers, the QSC KW series is hard to beat. Hit me up, I'll get you hooked up with a dealer in California, he's cutting me a GREAT deal on my system, and it's always nice to help out local businesses.
POTATO!
my bad :P Im not a big fan of JBL active gear. But there is something to say about an old dirty jbl passive pa! hah
PSN: Rcp_soundz
QSC makes great amps. possible the best alongside Crown. higher powered amps get expensive, so many amps would probly be your best bet to avoid paying thousands for more power. you won't get the cabin gain and the pressurization of a car enviroment, but i know for a fact car subwoofers can get loud outdoors and sound good doing so.
I won't purchase anything new from JBL. The SRX would be the only thing I would think of buying for "rider-ready" purposes. As far as JBL's actives go I won't touch them. They look great, but I need more than a doormat holder.
POTATO!
im fully with you on that one!!
PSN: Rcp_soundz
