kurupt305 Posted October 19, 2012 Report Posted October 19, 2012 hey whats up so im having problems trying to make this ten inch sub design for the tc i just cant figure out the torres calc maybe im doing it right maybe im not im looking for max dimensions of 20 wide 13 high and 13 deep id say im trying to keep space in the trunk so my wife can put stuff in the back my sundown e10 is going to be on 680 rms you think maybe you can design me a box so i can view it and figure out how to use torres by inputting your dimensions i want it between 1 and 1.2 cu ft tuned at 34/35 what ever you think would be better thanks
Joe X Posted October 19, 2012 Report Posted October 19, 2012 So here is a suggestion: Enclosure Specifications: Fb = 34.5 Hz Vb = 1.1 ft^3 External Height = 13 in External Width = 21.5 in External Depth = 13 in Port Width = 1 3/8 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front = 19 3/8 x 11 1/2 Back = 21 1/2 x 11 1/2 Left & Right Sides: Side 1 = 11 1/2 x 11 1/2 Side 2 = 12 1/4 x 11 1/2 Top & Bottom = 21 1/2 x 13 L Port Internal Assembly Parts: Front to Back = 10 1/8 x 11 1/2 Extension = 15 1/2 x 11 1/2 Assembly guide (generic dimensions): The port center line length is 28.5", the driver displacement is 0.1 cubic feet.
kurupt305 Posted October 19, 2012 Author Report Posted October 19, 2012 hey joe thanks alot man do i need to use the 45s or will i be fine without? this is my fiirst box trying to make it as simple as possible and whats this mean The port center line length is 28.5",
Joe X Posted October 19, 2012 Report Posted October 19, 2012 You can leave out the 45s, just round or slant the corner at the turn of the port (as shown), the centerline is the length of the port measured down the middle end to end.
