Advice On Alternator Wiring
hello there (Y)
Right then i have ordered a 140 amp alternator for my car.....that is like the most powerful one i can get made for my car, i will be running about 500-1000rms so that alt is plenty. My question is when i fit it i want to upgrade the wire from the alt to battery, i will use some 0-guage. but i am not sure if i will need a fuse of some sort or anything? i had a quick look around under the bonnet the other day and i saw a bunch of fuses that were 30amp and/or 60amp. will they be good enough or do i need higher amp one's? i have a stock battery that is 45AH if that is useful :)
Thanks a lot guys :)
Ben.
*Alpine Typr-R 12"
*JBL GTO 1200.1 Sub Amp
*Alpine PDX-4.100
*Rockford Fosgate Power 6.5's
*Rockford Fosgate Fanatics 6.5's Both in front doors
*0/1 Guage wiring from front Junction Boxes to 120AH Battery In Boot (battery removed because too small for alternator)
*140 Amp HO Alternator
*Alpine Head Unit
-------------------------------------------------------------------------x------------------------------------------------------------------------------
I would just use a 250 amp fuse im sure that it would never pull any thing more than 150 but to be on the safe side just go with a 250 to be honest i don't think you actually have to have one with 0 gauge could be wrong but ive done a few with out fuses and they have all been fine
yea i dont have a fuse on mine, just used some nice connectors on it, and ran it in a spot where it wont get hot or posibbly cut to ground out. Just be carefull when your running the wire. may also want to use some of that 0 to run a new ground. take it from the negitive from the battery and clean up a spot on the frame to attach it to. That will help alot also.
03 Trailblazer EXT LT
In Dash
Rear Flip Down
Polk Audio Font & Rear Stage
Hifonics Zeus 4 Chan Amp
Hifonics Brutus Mono Amp
12" Rockford Fosgate Power HX2
T-Line tuned to 45hz
18"BTL T-line @31Hz (9 weeks pregnant)
