most watts from 50 amp fuse
Its a mono but has 2 outputs
the sole reason why monoblock amplifiers have two sets of speaker terminals, is to make it easier when wiring multiple subwoofers. absolutely does not matter if you choose the left set, the right set, or you use all four. the outcome is the same.
So i have one sub at 2 ohms plugged in slot 1 and the other at 2 ohms plugged in slot 2 so it not bridged because it a mono not two channal.
so you wired all +'s together and all -'s together, essentially. yes? if you have a multimeter, that would be best. just read the ohm load on the amp. any set of terminals will give you the same answer.
  • Who's Online   1 Member, 0 Anonymous, 1244 Guests (See full list)
