Guest Posted October 29, 2012 Report Posted October 29, 2012 quality for sub hundred dollar subs will all generally be the same.
321slapinbass Posted October 29, 2012 Report Posted October 29, 2012 you said you want it theft proof by running 2 15's in a box that is big and hard to get out. and because i know prefab boxes are always on the small side (2 cubes for a 15), i would suggest doing a single sub setup like a vvx 15 or sa 15, but in a big box that is the same size as a dual 15 prefab. so the box will be 4 cubes for one 15 instead of 4 cubes for 2 15's . by doing this you will still have a "theft proof" set-up because of the big box. and you will also still have good output even though its one sub instead of two because your going up to a higher line of sub.. 2000 Dodge Durango Subs - (2) SKAR VVX 15 D2's Box - 7.2 ft^3 @ 33hz, 120 in of port Sub amp - Digital Designs M2 @ .5 ohm Mids + Highs - PRV Audio Mids + Highs amp - Hifonics 2000.4 Headunit - Alpine CDE-100 Equalizer - Clarion EQS746 Batteries - Mopar group 27 + (2) C&D 52ah Wiring - 1/0 BIG 3, (2) runs 1/0 Alternator - Singer 250A 147.79 dB @ 35hz - burp - sealed on dash 147.47 dB @ 35hz - music - sealed on dash YOUTUBE: http://www.youtube.com/user/321slapinBass/videos
