pintich Posted October 24, 2012 Report Posted October 24, 2012 hey, i have no ide how big box i need to make so i get out all from my sub i am new to this so i dont know what numbers i should cut all pieces in, and i will run the kicker 12" with a amp at 800w. (i have pretty mouch space in my trunk)
Joe X Posted October 24, 2012 Report Posted October 24, 2012 Post your max dims for a box and the exact models of amp,sub and vehicle.
pintich Posted October 27, 2012 Author Report Posted October 27, 2012 its a "Kicker Comp 10C122" (its a 12"), amp= "Ampire MB400.1", my car is a SAAB 900s 95. I have max space of H= 45, W= 60, D= 42 (its in Centimeters dont know what that is in inches) sry for taking so long time to answer but i had mouch to do.
Joe X Posted October 27, 2012 Report Posted October 27, 2012 Alright since you are giving metric dimensions I am replying in metric also, wood thickness is 18mm which would be the nearest available thickness to the 3/4" most commonly used 3/4" wood. Enclosure Specifications: Fb = 34.5 Hz Vb = 2 ft^3 External Height = 38 cm External Width = 55 cm External Depth = 42 cm Port Width = 4.25 cm Cut Sheet List: * All Dimensions in Centimeters. * Wood Thickness is 1.8 for all Parts. External Enclosure Parts: Top & Bottom = 55 x 42 Left & Right Sides = Side 1 = 38.4 x 34.4 Side 2 = 40.2 x 34.4 Front = 48.95 x 34.4 Back = 55 x 34.4 L Port Internal Assembly Parts: Front to Back = 34.15 x 34.4 Extension = 11.25 x 34.4 Assembly guide (generic dimensions): Let me know any questions or changes, if 18mm wood is not available to you, let me know what is that you can get and I will change the above.
pintich Posted October 27, 2012 Author Report Posted October 27, 2012 tanks alot! it looks realy good, and that is for SPL right?
zydrix Posted October 27, 2012 Report Posted October 27, 2012 tanks alot! it looks realy good, and that is for SPL right? thats a good box design joe did for u. but u wont want that tuned for spl, if im not mistaking spl tunning is really high, an it wont sound good on music, the 34hz joe has that tuned to should sound good on music, but now if u are wanting spl, u might want to get much more high power handling sub(s) an a much bigger amp. that sub wont do anything really for spl. hope this helps. My build 98 s10 2.2 3 american bass HD 15s with psi soft parts. (on there way here) atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build) alpine 6.5s in doors infinty 4x6s in dash. clarion cz201 HU. mechman 240a H/O alt stuff i still need. SHCA 2/0 wire SHCA 1/0 to 2/0 adapters Atomic AT-3000.1 Lots of sound deadner new mids an highs, still debating on what to do. A few Deka g31 batts.
pintich Posted October 27, 2012 Author Report Posted October 27, 2012 tanks alot! it looks realy good, and that is for SPL right? thats a good box design joe did for u. but u wont want that tuned for spl, if im not mistaking spl tunning is really high, an it wont sound good on music, the 34hz joe has that tuned to should sound good on music, but now if u are wanting spl, u might want to get much more high power handling sub(s) an a much bigger amp. that sub wont do anything really for spl. hope this helps. oh okey, thanks that's good to know
Joe X Posted October 27, 2012 Report Posted October 27, 2012 tanks alot! it looks realy good, and that is for SPL right? Don't know if your amp does rated power (400WRMS), if it does, limit your gain AND engage your subsonic filter.
pintich Posted October 27, 2012 Author Report Posted October 27, 2012 but can it then be better to use a "Ampire VLEX12" ? it's on 350 RMS and 700 Watt max. But it's on 4 Ohm, can i make it to 2 ohm?
zydrix Posted October 27, 2012 Report Posted October 27, 2012 that sub is 150rms. i wouldnt run it over 150rms. if your are wanting a sub thats dirt cheap that can take a little more power. an might be easier to work with. http://www.sonicelectronix.com/item_37709_Hifonics-HFX12D4.html get that. My build 98 s10 2.2 3 american bass HD 15s with psi soft parts. (on there way here) atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build) alpine 6.5s in doors infinty 4x6s in dash. clarion cz201 HU. mechman 240a H/O alt stuff i still need. SHCA 2/0 wire SHCA 1/0 to 2/0 adapters Atomic AT-3000.1 Lots of sound deadner new mids an highs, still debating on what to do. A few Deka g31 batts.
