sierra mist Posted October 25, 2012 Report Posted October 25, 2012 I sanded thus area down in hopes it will be a good grounding location. Do I have the green light to proceed with this or pick another spot?
8ight Posted October 25, 2012 Report Posted October 25, 2012 That looks solid. May I ask what you are grounding to it? Amps? I wouldn't ground amps there but I always use a dedicated earth run for amps so I'll let someone else have the final say on that. I'm gonna hate
sierra mist Posted October 25, 2012 Author Report Posted October 25, 2012 That looks solid. May I ask what you are grounding to it? Amps? I wouldn't ground amps there but I always use a dedicated earth run for amps so I'll let someone else have the final say on that. just the HU and steering wheel control adapter.
KillaCam Posted October 25, 2012 Report Posted October 25, 2012 Your amp should be grounded to a sanded spot on the frame. What exactly are you grounding? Behind the dash seems like a weird spot to even think about grounding an amp that's usually in the back of the vehicle. And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log
8ight Posted October 25, 2012 Report Posted October 25, 2012 That looks solid. May I ask what you are grounding to it? Amps? I wouldn't ground amps there but I always use a dedicated earth run for amps so I'll let someone else have the final say on that. just the HU and steering wheel control adapter. Sure, that's fine then I'd gladly ground something light like that there. I'm gonna hate
