Go-N-Def Posted October 29, 2012 Report Posted October 29, 2012 1 Are you supposed to use a crossover like the comp sets? or do you wire the speaker direct? Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
Omega5002 Posted October 29, 2012 Report Posted October 29, 2012 I see people run active when they use pro audio, never seen anyone use a passive crossover. 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
Go-N-Def Posted October 29, 2012 Author Report Posted October 29, 2012 lost here whats active mean? Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
Truconcept Posted October 29, 2012 Report Posted October 29, 2012 an active crossover is one thats powered not like a bass blocker(passive crossover) which is put in the speaker line **actin bad like a kid at six flags**
Go-N-Def Posted October 29, 2012 Author Report Posted October 29, 2012 like audiocontrol ? Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
Truconcept Posted October 29, 2012 Report Posted October 29, 2012 yup **actin bad like a kid at six flags**
Go-N-Def Posted October 29, 2012 Author Report Posted October 29, 2012 ok, in the set-up would'nt that call for a 2 amps. like 1 for tweet and 1 for mids Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
kalilac619 Posted October 29, 2012 Report Posted October 29, 2012 not necessarily you can run 2 way active with one amp if the amp allows... 2000 Suburban 6 runs of 2/0 12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door 475ah of yin long LTOs Triple 370 Amp Autotech Alts mids amps 2 Crescendo Skyway 3ks compreesion horn amp crossfire 800.4 Tweet amp Crossfire 2000.4 sub amp: 4 Crossfire XT 8ks Subs: 8 18 in Crossfires in a 4th order Best Scores at events… 163.5@38hz DBdrag sealed on the dash… 164.3 outlaw…162.9 Meca headrest
Tiger Posted October 29, 2012 Report Posted October 29, 2012 We are currently running a 3 way active setup with 2 amplifiers (Pro Audio gear) 2 pairs x 10" midbasses running bridged off a 4 channel amp (4 ohm load) 2 pairs x 6.5" midranges running 2ohm stereo on 2 channels of a second 4 channel amp 1 pair x 1.75" horn tweeters running off the remaining 2 channels off the second 4 channel amp (4 ohm load) I can't remember the crossover settings (my friend has them at some sort of secret recipe) Project [iBWALL] Budget install - high efficiency - CRAZY LOWZ! Sub-less Toyota Camry Sedan 134.7dB @ 52Hz... off the back shelf... and NO SUBS!!!
