Yates Posted October 30, 2012 Report Share Posted October 30, 2012 2 18" blaupunkt vpw 460 on a Audio Pipe 3000d getting 1500w rms each bridged at 2 Ohms is that better that using the single channels at one Ohm or is it the same car is a Subaru Grandwagon 1996 the demention between the wheel arches is 960mm port facing back or forward which is louder specs are here Subwoofer with a diameter of 460 mm and 5400 watts of max power. Specifications System Subwoofer Diameter (mm) 460 Peak power handling capacity 5400 watts Nominal power handling capacity 1800 watts Sensitivity 94 dB (2.83V/1m) Frequency response Hz 20 - 200 Hz Impedance 2 x 2 Ohm Cone material Carbon/fibreglass Installation depth 245.0 mm Installation Ø 420.0 mm Hole circle 452.0 mm Included Design cover Thiele/Small parameters Fres 37 Hz Qts 0.6 Qes 0.71 Qms 3.8 Vas 36.7 l Xmax + / - 15.0 Enclosure recommendation Bass reflex 60 litres Tunnel Ø 2x 10 cm Tunnel length 2x cm Vid for how I would like it same sub type Link to comment Share on other sites More sharing options...
94jettameowpsst Posted October 30, 2012 Report Share Posted October 30, 2012 I'm not sure what you're asking but your mids and highs are squeaky fn clean! 150.1 @ 38hz142.3 @ 20hz (windows down)Only 2 batteries Link to comment Share on other sites More sharing options...
alaskanzx5 Posted October 30, 2012 Report Share Posted October 30, 2012 I'm not sure what you're asking but your mids and highs are squeaky fn clean! he only posted a pic of what he wants his finale setup to look/sound like. that isn't his vids just vids he found. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
Yates Posted October 30, 2012 Author Report Share Posted October 30, 2012 I'm not sure what you're asking but your mids and highs are squeaky fn clean! he only posted a pic of what he wants his finale setup to look/sound like. that isn't his vids just vids he found. some people just need to read the full story Thanks alaskanzx5 Link to comment Share on other sites More sharing options...
Yates Posted October 30, 2012 Author Report Share Posted October 30, 2012 bump Link to comment Share on other sites More sharing options...
