A little upgrade on the Stock oem Rockfordfosgate Sytem in my 2009 Lancer
Replaced the Oem 10'' with
Oem Deck for now
15' Kicker L5 ''' 750 Rms ''''
kenwood kac-9105d 1800 Watt Class D Mono amplifier
Had A hard time to fit my box @ 3cubic when it would be best being 6cubic for this sub ,
First We taped into the rear speakers with a crossover , dint work the best so we later taped into the oem sub wiring ,
All ran well till a few minor screw ups when i dint carpet my box soon enough and the sub slid into the amp riping out wires then i later
fried the oem Car amplifer resulting zero audio in the car ' dint bother re asemble the back seats as i was troubleing allot of rattles ,
i eliminated quite a few but some still remain that i will have to figure and fix ,
still need to dynamat in the future ,
Another Oem amp later i got everthing working again ,
And Final and done
looking forward to seeing more. Video wont load for me
2004 Malibu Classic http://www.stevemead...aq-25-jeep0312/
Kenwood 352U HU
(2) Incriminator Audio Death Row 12''
Soundstream Tarantula 1300W
MTX 6.5'' mids &
Infinity 4x6's in front doors
Building as money comes in... beauty panels and amp rack
1996 Jeep Grand Cherokee Traded for a 2004 Malibu
2wd-4wd conversion
4in. lift
32'' Tires
2 Alpine 6.5 in front
2 Sony 6.5 craploads in rear
Build: http://www.stevemead...__fromsearch__1
1999 Suzuki Sv650(Work in Progress)
That's odd , im still uploaded more videos hopefully they work
So far as for vibration fixes since the new system ,
Rear Seats Top plastic lid , Solution foam on all edges of the plastic lid.
Will dynamtat the metal later ,
Both rear pillar"s and airbags used some normal house insulation , also under lid and inside the rear belt buckle
Isulation into above the front dome lights next to moon roof ,
Got to investigae the side pillars front dash and front airbag pillars as i got many other vibrations witout the sub on ,
Friend of mine has that same car, with the same color as well. He tells me trunk space is small, but looks like a good start so far.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
The l7 doesnt look bad but give it a bigger box and it will shine. My friens had one in a box like urs and soon as we built a 4 cube box it started trying to blow out the sun roof and make the truck fall off. All one less then 600rms iirc
vids are working now
Kenwood 352U HU
MTX 6.5'' mids &
2wd-4wd conversion
4in. lift
32'' Tires
I was actually aiming for a 6cubic box ,
However the complexity of this trunk as the width and the beam makes it hard to fit a 15''
i actualy had a buddy help as im not great with this carpentry ,
So at this time the box sit's at 3cubic
It pounds pretty decent however it seems or i would espect a little more from this setup '
perhaps a bigger amp to push this in the future when i have money to waste on this ,
After it was done buddy tought of another way or how to perhaps have the full cubic needed ,
With being able to take the sub out if required and not taking my full trunk just for the sub ,
