Just Put some new Rotors on my Baer Setup
They are on...my question is, are they supposed to be settled in? It seems like the pads are just rubbing on the rotors, im not sure if thats because they are all brand new, or something is wrong. Example, i let off the gas and the car doesnt even Idle forward.
Currently:
2015 Evo X WW
Forgestar F14 18s --Rally Armour Mudflaps
ETS 3.5" FMIC, CAI, Open Dump DownPipe, Test Pipe, Ultimate Racing Catback, BLEVINS TUNE, Fortune Auto 500 Coilovers
Build:
Crescendo Mezzos x2
Crescendo 800.4, 1500.1
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Sky High Audio Wiring
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
3.8L S/C-few modsWheels: Ruff Racing 280 19x8.5 Sub: Fully Loaded
12" Fi BTL Amps: Autotek MM3000.1d Sundown SAX-100.4HU/Tweets/mids:
Alpine D310 + H701, TBI HDSS tweets, Mpyr audio 65m x4extra sheit:
knukonceptz 0, 4, rcas, speaker wire EA 200amp alt HC 2400
TEAM DEADLY HERTZ!!
Financial Consultant- Charles Schwab
This may go without saying but are they fully bled?
Something you could check is see if it is just the front of back pad rubbing. I once worked on a car (granted it was a raced out porche 914 with swapped breaks) that had a caliper shimming issue so we had to shim the caliper so that it was spaced correctly for the rotor, otherwise it would rub.
What do you mean fully bled? Im not a machanical kinda guy lol i think i know what you mean butt i dont want to answer without fully knowing what you mean.
Another issue, when i put the rotors on they did not seem to want to set flush to the front end. When i put the wheels back on and tighted the lugs they were set in, but previous to that i could not set them flush even after putting some force to them.
Currently:
2015 Evo X WW
Build:
Crescendo Mezzos x2
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
TEAM DEADLY HERTZ!!
Took it all apart again. looks like there was some rubbing issues on a couple spots on the Caliper Braket....gunna grind those down and put it back together
Currently:
2015 Evo X WW
Build:
Crescendo Mezzos x2
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
TEAM DEADLY HERTZ!!
By fully bled I mainly just meant bled properly. Shouldn't need to completely flush the system or anything.
However... Are these rotors a different size than your last ones? If you are having rubbing on your caliper bracket it may be a sign of something worse that you don't want to just cover up.
After hours of fkking with this yesterday we found out the Rotors were the wrong size...the old rotors were actally 12 1/2...closer to 12 5/8. So i assumed 13 bc when i measured them on the car it was way closer to 13 then 12. There was some major grinding issues. I spoke with Baer and they are sending me new caliper brakes and hardware. Hopefully itll be here tomorrow.
Currently:
2015 Evo X WW
Build:
Crescendo Mezzos x2
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
TEAM DEADLY HERTZ!!
Just had and, OH SHITT, moment. I dont think with the new bracket my winter wheels will fit...I have and inch or so room with the current wheels and the winter wheels are and inch smaller.
Currently:
2015 Evo X WW
Build:
Crescendo Mezzos x2
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
TEAM DEADLY HERTZ!!
Something is wrong....ur rotors are going to be smaller after wear bc the pads wear them down.
And you need to bleed ur brakes in order for them to work correctly if you lost brake fluid.
Do not shave down those rotors, you cannot shave down drilled and slotted rotors
This is Hunter Johnson's Mobile Accnt :)
06 Scion Build
why the hell would i shave down the rotors?
Currently:
2015 Evo X WW
Build:
Crescendo Mezzos x2
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
TEAM DEADLY HERTZ!!
  • Who's Online   0 Members, 0 Anonymous, 1770 Guests (See full list)
