Viper 211HV with after market door lock actuators
I'll do some tests with a voltage meter and check all the wiring and if I can't get it I'll take it somewhere.
Again thanks for the help.
Avery
2012 Jeep Wrangler 3.6 W/ 6 Speed
Build Log
2011 Ford F-150 SVT Raptor 6.2
Build Log
YouTube
well due to the fact your using actuators and bypassing the doors locking feature you only need to use one of the unlocks for each door and setup a single and double push on the unlock button for how many doors you would like to open. but your going to need a relay if you have a two wire actuator, if you have a 1 wire actuator then you should be fine to hook it up as all it should need is a 12v power source to pull in and allow the door to open
never done a viper, but did something similar, connect blue and blue/black together for unlock, connect the green/black to lock, ground the violet and violet/black.
edit - take out the relay, connect the wires as it was before, just ground the violet AND violet/black. don't ask me why, but the last 2 alarms I did somehow worked that way. lol.
How do the Japanese feel about bass?
You know that since 03/11/11
Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.
im pretty sure the op wont even notice if it gets even smaller.
Refs - Pstone11, porksoda, coleman
  • Who's Online   1 Member, 0 Anonymous, 1631 Guests (See full list)
